Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
The circle clip that holds on the idler gear inside the cover plate fell off......fuching .75 part.....
Crazyhippy |
Insert witty comment here... ![]() ![]() ![]() Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None ![]() |
What else did it take w/ it?
Now you know the trans is done right... never have to worry about it again. BJH |
Joe Bob |
Nothing internal is bad....gasket kit, new circlip and I'm gonna replace the 36mm nuts on the end of the shafts....some Swepco and back in it goes....the nuts are like 25 bucks each....
Crazyhippy |
pretty bad when the most $$ part of your tranny re-build is the gear lube...LOL
BJH |
Joe Bob |
36 bucks.....coulda been worse.....
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
Your right, it beats installing a new set of sparkplugs.
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,422 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
In a generic sort of way this proves the old saying...
"A $3,000.00 Picture tube will blow out to protect at $.75 fuse" |
Joe Bob |
Yeah...with the engine and trans out...it's also easier to replace the hood gas struts that went dead.
Got lemons? Make lemonade.... |
Lo-Fi Version | Time is now: 4th July 2025 - 12:15 AM |
