Camp 914 rear trunk mounts, need a measurement |
swood |
Jan 20 2007, 10:38 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Can anyone give me a quick measurement to locate the lower mount?I don't have the engine lid in or stock springs to help me figure out how high up the trunk should raise. Ready to drill... (IMG:style_emoticons/default/smash.gif)
Tanks. |
pete-stevers |
Jan 21 2007, 12:29 AM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
don't you dare drill untill you are damn sure....
did you not get instructions??? i would measure but i am at home and warm.....shop....cold |
swood |
Jan 21 2007, 10:27 AM
boxstr |
Jan 21 2007, 03:58 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Steve put the shock on the upper mount, remove the lock ring first. Then lower the lower end of the shock to the side of the trunk, position the lower bracket and mark with a Sharpie. This will give you the location to drill at.
If you need me to I can fax or send an instruction sheet. Craig C. Laughlin CAMP 914 |
swood |
Jan 22 2007, 12:14 AM
I have the upper mounts on, but don't really know what the full range of opening the hood should be in order to place the bottom mount. That's kind of where I'm stuck. I have the instructions you included.
This reminds me I need to send you $. (IMG:style_emoticons/default/smile.gif) |
boxstr |
Jan 22 2007, 12:26 AM
Steve,I can take a measurement on a car in the morning call me at 503-799-5794.
Craig |
Lou W |
Jan 22 2007, 01:18 AM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
I did not have my trunk lid on when I mounted mine, I put the hinge in the maximumn open position, attached the shox with the trunk base mount attached and located it accordingly. It worked fine.
Attached image(s) |
Lou W |
Jan 22 2007, 01:22 AM
Here a couple pictures completed;
Attached image(s) |
Lo-Fi Version | Time is now: 6th June 2024 - 05:42 PM |
