neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,919 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
corvair, must have a reverse rotation ring gear also.
up to 66 muncie 4spd. 66 and later had a saginaw 4spd. |
dlo914 |
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 ![]() |
interesting spoiler on the end of the targa top...
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
corvair, must have a reverse rotation ring gear also. up to 66 muncie 4spd. 66 and later had a saginaw 4spd. I thought corvair engines spun the other way. (which would mean using the trans for a mid engine application with a "normal" engine shouldn't require reversing anything on the trans) |
Crazyhippy |
Insert witty comment here... ![]() ![]() ![]() Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None ![]() |
Odd setup. Lot of work for no real gain though...
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Yeck....
sixnotfour |
QUOTE I thought corvair engines spun the other way. (which would mean using the trans for a mid engine application with a "normal" engine shouldn't require reversing anything on the trans) yup looks different cause in a corvair, the chev v8 inputs on the trans end . they did make reverse rotation ring gears. thanks |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
I wonder how that radiator set up works?
turbo914v8 |
Member ![]() ![]() Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 ![]() |
drive-ability |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 ![]() |
I wonder how that radiator set up works? I would bet it does not work. I had a 66 convertible Corvair with a 350 and a 4 speed 25 years ago. Mine was a crown conversion. Truly a clean car, 60k original miles. I saw that G.M. transmission and thought, hum, surely stronger than a 901. I pushed my car and didn't brake the trans, just one set of spiders. |
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
Radiator set up can't possibly work, can it?
Car is local to me if anybody wants a PPI. Looks to be the same car that was on E bay last spring. As I recall last time it was listed, it had some pretty screwed up info in the description and some much less flattering pictures in the ad. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 11:33 AM |
