Full Version: eBay 914 V8 with GM? 4 speed transmission
neo914-6
914 V8 on eBay
sixnotfour
corvair, must have a reverse rotation ring gear also.
up to 66 muncie 4spd.
66 and later had a saginaw 4spd.
dlo914
interesting spoiler on the end of the targa top...
bondo
QUOTE(sixnotfour @ Jan 31 2007, 11:39 AM) *
I thought corvair engines spun the other way. (which would mean using the trans for a mid engine application with a "normal" engine shouldn't require reversing anything on the trans)
Crazyhippy
Odd setup. Lot of work for no real gain though...
Joe Bob
Yeck....
sixnotfour
yup looks different cause in a corvair, the chev v8 inputs on the trans end .
they did make reverse rotation ring gears.
thanks
sean_v8_914
I wonder how that radiator set up works?
turbo914v8
QUOTE(sean_v8_914 @ Jan 31 2007, 06:37 PM) *
I would bet it does not work.
drive-ability
QUOTE(turbo914v8 @ Jan 31 2007, 06:31 PM) *
I had a 66 convertible Corvair with a 350 and a 4 speed 25 years ago. Mine was a crown conversion. Truly a clean car, 60k original miles. I saw that G.M. transmission and thought, hum, surely stronger than a 901. I pushed my car and didn't brake the trans, just one set of spiders.
aircooledboy
Radiator set up can't possibly work, can it?
Car is local to me if anybody wants a PPI. Looks to be the same car that was on E bay last spring. As I recall last time it was listed, it had some pretty screwed up info in the description and some much less flattering pictures in the ad.
