tranny help needed..., changing bushings |
scottb |
Nov 23 2003, 12:58 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
there is a set pin (red arrow) that i need to remove to replace the non-existent bushing (blue arrow) any suggestions on this process? i tried banging away but the wife said to get back to work on the car (bada boom!) (IMG:style_emoticons/default/mueba.gif)
really, started to smack away (IMG:style_emoticons/default/smash.gif) but figured i had better inquire first.... so i drink beer and wait.... (IMG:style_emoticons/default/beer3.gif) thanks all...... |
TheCabinetmaker |
Nov 23 2003, 01:04 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
If I am looking correctly, The bushing is missing because there is not supossed to be one there.
TheCabinetmaker |
Nov 23 2003, 01:05 PM
there is a bushing where the shift rod tube enters the housing, and the ball cup bushing on the linkage
scottb |
Nov 23 2003, 01:10 PM
there is the wafer thin remants of a plastic washer.....
if i don't need to replace it, all the better. |
MarkV |
Nov 23 2003, 01:12 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
You need to remove the set/cone screw. You can't drive that pin out with the shifter console on the car. There is a bronze busing inside the shifter console but I doubt that that is your problem. Change the plastic cup bushing & the plastic shifter rod bushing.
Attached image(s) |
MarkV |
Nov 23 2003, 01:14 PM
QUOTE(scottb @ Nov 23 2003, 11:10 AM) there is the wafer thin remants of a plastic washer..... if i don't need to replace it, all the better. That wafer thin washer is the correct part. |
scottb |
Nov 23 2003, 01:15 PM
went at that set screw and bent the shit out of an allen wrench. time to find a wrench with a bit more testosterone.. (IMG:style_emoticons/default/gunner.gif)
TheCabinetmaker |
Nov 23 2003, 01:25 PM
The wafer thin washer the arrow is pointing to, is all that's supossed to be there. There is nothing there to replace. The red arrow is pointing to a double roll pin that drives out with a punch. Don't drive it out. It won't help you. Make sure you use a metric allen on the cone screw, and shoot it with some penetrating oil if it's stuck.
Lo-Fi Version | Time is now: 8th June 2024 - 03:21 AM |
