Timesert, Installation Tips |
solex |
Feb 11 2007, 02:29 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hi,
I'm about to install a timesert in the head to fix a pulled out exhaust stud and was wondering if anyone had some tips on keeping the drill straight when drilling and tapping the hole? The engine is in the car and I will be on my back... Thank you, Dan |
jimkelly |
Feb 11 2007, 02:48 PM
wear eye protection and get a good light on the area.
SGB |
Feb 11 2007, 08:54 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Don't drill all the way at first. go just a little way, then see if you can get the tap to start before it has less to grab at the tip. Get a decent T-shaped tap handle so you can put some muscel behind it. I lay on a creeper in sich a way that I could wedge one hand between the t handle and my shoulder so that I could push against my wrist with my upper body while I turned the tap. Use WD-40 or some other lubricant liberally. For me the hardest part was getting the tap to bite- I kept digging a hole until I used my shoulder. The head material doesnt shave, but flakes.
So.Cal.914 |
Feb 11 2007, 09:39 PM
If you follow the instructions above be careful, taps are very brittle and will
snap if over stressed. And if it does you will have one hell of a time getting the broken tap out. Easy does it, turn the tap in a little and then back out, in and out adding lube as you go. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:57 PM |
