Cracks in the longs..., another one |
McMark |
Feb 20 2007, 01:54 PM
This is my second crack discovery. Same place. This one is very early and is only 1" long and easily welded. Lucky to catch it now before it gets really bad.
Attached image(s) |
McMark |
Feb 20 2007, 02:39 PM
Another one, cleaned up for welding. You can clearly see the crack here.
Attached image(s) |
jgara962 |
Feb 20 2007, 02:44 PM
Yo, this is how I roll Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California |
Thanks for catching this and patching her up! (IMG:style_emoticons/default/clap56.gif)
dr914@autoatlanta.com |
Feb 20 2007, 03:11 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
John |
Feb 20 2007, 03:18 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I have seen nearly identical cracks in the middle of the longs like that (both drivers side and passenger side.
I think there must be a stress concentration near that location. I remember reading a long time ago in an old UpFixin that this was an area that should have the cage attached to (in a caged car). (They had a car on a sort of a vibration machine to determine node points/chassis weak points for a cage installation) This is also another good reason to do the Engman (or similar) inner long reinforcement. The floor in the area just below this area can also begin to tear. just my $0.02 |
jimkelly |
Feb 20 2007, 04:16 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
jgara962 |
Feb 20 2007, 04:42 PM
highways |
Feb 20 2007, 06:21 PM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
He sure nipped that in the bud! (IMG:style_emoticons/default/tooth.gif) |
jgara962 |
Feb 20 2007, 06:49 PM
He sure nipped that in the bud! (IMG:style_emoticons/default/tooth.gif) A 1" crack and Jim is haulin' out the sawzall! (IMG:style_emoticons/default/biggrin.gif) |
Van914 |
Feb 21 2007, 04:13 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
Mark,
Mine cracked in the same place. Now I have a Safety Device Cage and don't worry about the flex. Van914 |
PinetreePorsche |
Feb 21 2007, 05:46 AM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
McMark: Just curious--is this a daily user, an autocross car, a track car, or what--what kind of stresses does it see? How big (hp, tx) and heavy (4, 6, or 8) is the motor? So the rest of us will know whether to get out the magnifying glass.
jgara962 |
Feb 21 2007, 11:08 AM
McMark: Just curious--is this a daily user, an autocross car, a track car, or what--what kind of stresses does it see? How big (hp, tx) and heavy (4, 6, or 8) is the motor? So the rest of us will know whether to get out the magnifying glass. I purchased the car from another club member almost two years ago. He used it regularly and I suspect it also saw its share of track time at PCA events. Since purchasing it, I've only driven it maybe 5,000 miles and one autox. It has 2.0/4 in it. |
McMark |
Feb 21 2007, 12:02 PM
Mark, Mine cracked in the same place. Now I have a Safety Device Cage and don't worry about the flex. Van914 The other one I've seen in person was a much larger crack, and was in a track car with a cage. (IMG:style_emoticons/default/ohmy.gif) It's still worth keeping a close eye on this area in a track car. Street cars probably won't ever see a problem there. |
Lo-Fi Version | Time is now: 10th June 2024 - 08:38 AM |
