Racing tranny questions |
r_towle |
Nov 25 2003, 01:12 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi,
Aside from taking them apart, how could I tell what gears are in what tranny??? If I open them up, are there numbers on the gears that I could find without taking it apart further??? I may just put each one in the car, drive it and see based upon speed/tach what I have.... Any ideas??? Rich |
Brad Roberts |
Nov 25 2003, 01:16 PM
I gave up on the letters. I count the teeth. I mark one tooth with a paint marker and count from there.
A lot of the times.. I mark the top of the tranny with what it has in it.. I have seen Brad Mayeur do this also. B |
Brad Roberts |
Nov 25 2003, 01:18 PM
You could put the tranny into each gear and count the revolutions. The R+P is the constant. Mark the input shaft and turn the output flanges.
B |
r_towle |
so, after I count the teeth, hopefully you can decifer what they were trying to do...
Looks like two of them have no first gear...just deleted... Rich |
Qarl |
Nov 25 2003, 01:22 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
What are the stock gears? (Letters?)
Brad Roberts |
Nov 25 2003, 01:24 PM
That is "different". My guy's have at least 1-2 tranny's with 904 main shafts or custom shafts that allow 3rd gear to go in place of 1st... so they have 5 "race" usable gears. Have to push/pull the car to grid or shutter it in a third gear.
If we have a box with first.. we use it. B |
Brad Roberts |
Nov 25 2003, 01:29 PM
ZD is stock 4cyl 5th
F is stock 4cyl 2nd A is first I forget the stock 3rd/4th Typically people will build a M3/S4/X5 box. This is a cheap racers box to build. B |
Lo-Fi Version | Time is now: 11th June 2024 - 01:13 PM |
