914/6 fan question, big pulley-little pulley? |
hellsbend |
Feb 27 2007, 01:06 AM
Member Group: Members Posts: 70 Joined: 27-February 06 From: Lakeport, CA Member No.: 5,646 |
i've got a original 914/6 2.0 engine and was wondering if a later 1.67:1 fan/pulley would work on it, and if it would help keep the temps down with the faster spinning fan vs. the stock 1.3:1 fan. Would it cause any problems with the stock alternator besides a bit faster wear?
736conver |
Feb 27 2007, 08:08 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
i've got a original 914/6 2.0 engine and was wondering if a later 1.67:1 fan/pulley would work on it, and if it would help keep the temps down with the faster spinning fan vs. the stock 1.3:1 fan. Would it cause any problems with the stock alternator besides a bit faster wear? Why are your temps so high in the first place? How hot are you running? Changing pulley might not be the best solution. |
davep |
Feb 27 2007, 11:49 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
hellsbend |
Feb 27 2007, 03:42 PM
thanks for the heads-up on the Pelican thread, it had some good data there. I haven't fired this engine up yet so I don't know what the temps will be be like, but I've owned a ton of air-suckers and they all ran hot here in our 110 degree summers and big hills, I doubt this one will be any different so I'm kind of thinking more cooling the better. It sounds like the 245 mm 11 blade 930 w/straight tips and a 1.67:1 ratio is the way to go, even if it is a bit noisy. Phil
Lo-Fi Version | Time is now: 9th June 2024 - 07:21 PM |
