Lowering the back end, guidelines? |
jr91472 |
Mar 3 2007, 08:24 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Hey gang,
I am a relatively new a/x'er. My PO is my older brother who originally restored my 914 and a/x'ed with SCCA in the 80's. I learned something about my car from him the other day I didn't know. He place removable spacers (about 1 1/2" height) under the rear springs. They are split and held together on the shock by a hose clamp so they can easily be removed for a/x duty, thus lowering the rear end. He swears by this and had the performance to back it up. What do you guys think? I haven't tried it yet, so I don't know what the actual ride height would be before and after. What should I look for? Front height and rear height should be equal? Front slightly lower? I am going to remove the spacers in a day or so and take some measurements. thanks (IMG:style_emoticons/default/beer.gif) |
jr91472 |
Mar 3 2007, 08:53 AM
Also,
For measuring ride height, is their a "standard" location from which to measure? |
Rough_Rider |
Mar 3 2007, 10:09 AM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
Use the doughnuts for measuring rideheight. Else whatever you use make sure you consistent.
A ride height tool makes checking real easy & fast just slide it in under the area to be checked. You can even make something on the cheap out of scrap wood. Body position should be flat Or slightly nose down. The only problem i see with a spacer block is potential for alignment change. IMO stick with one ride height for road & AX. Consider a coilover conversion for rear it'll give you 4"-5" of adjustment & cheap spring rate changes. However be warned mod's are a slipper slope. IMO if your bro used to drive it competitively then there should be nothing wrong with it, so go have fun & upgrade with your experience. Attached image(s) |
SirAndy |
Mar 4 2007, 01:10 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
get adjustable perches ... they slip over the shock and give you an infinite amount of adjustment ...
(IMG:style_emoticons/default/bye1.gif) Andy Attached image(s) |
grantsfo |
Mar 5 2007, 09:07 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Go with adjustable perches. Thats what most low budget AX/track people do.
Mueller |
Mar 5 2007, 03:09 PM
seems like a PITA....
so you are saying for everyday driving he has the rear of the car 1.5" higher and then only for auto-x he removes the spacer and lowers the rear?? what about the front??? is the rear 1.5" lower than the front of the car during auto-x (so the nose sticks up??) like mentioned above, generally, for best all around handling the rear is .5" higher than the front (measure at the donuts under the car) I have seen a few people swear that the cars handle better if the rear of the car is way lower than the front, and that is just obsurd...it works, but far from ideal |
Lo-Fi Version | Time is now: 9th June 2024 - 07:16 PM |
