DIY: Brakeline & Fuel Line Cleaning, need help & searches do not bring up the responses |
greybeard50 |
Mar 6 2007, 01:33 PM
Newbie Group: Members Posts: 46 Joined: 24-September 06 Member No.: 6,909 |
I am the proud owner of 912E #18xx & need to undo 6 years worth of sitting in the garage.
Engine & trans to be dropped shortly & a re-built motor standing by Trans majic by Dr. Evil new Master Cyl re-build calipers & pedal asm by Eric Shea (new soft lines & what else???) fuel tank remove & boilout (new soft lines & what else???) I need help in flushing out the hard fuel & brake lines. Replace? Flush w/ boiling water? w/kerosene? w/ ???????? |
SLITS |
Mar 6 2007, 02:32 PM
I just blow air thru them at 125 psig.
If you want to clean lacquer outta the fuel lines you will have to use carb / brake cleaner, fill them, let'em sit for a day and then blow air thru em. My opinion only.......... |
Cap'n Krusty |
Flush the brake lines with alcohol, available at any paint store. Flush the fuel lines with fuel, or maybe alcohol. Plan on replacing the flexible brake hoses, too. I recommend, for safety reasons as well as cost, the OE rubber hoses. The Cap'n
Joe Owensby |
Mar 6 2007, 06:05 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Should the solid lines be replaced? Not to hijack your thread, but was just curious as to the need to replace my 30+ year old ones.
Lo-Fi Version | Time is now: 4th June 2024 - 05:22 AM |
