Seatbelt harness options using stock mounting |
ahdoman |
Mar 7 2007, 05:06 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Anybody know of a racing type harness that uses the stock seatbelt mounting locations?
Johny Blackstain |
Mar 7 2007, 05:47 PM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Anybody know of a racing type harness that uses the stock seatbelt mounting locations? This one mounts in the stock locations. The only modification is a hole has to be drilled in the floor, in front of the drivers' seat for the submarine belt. Shoulder harness go around the bar & the par bolts tho where your upper seat belt pivots are now. Lap belt bolt into stock holes as well. I have no idea who makes the bar & the belts are obviously Simpsons. I actuall sold this to someone here on the board... they're from Texas & can ring in anytime. (IMG:style_emoticons/default/cool_shades.gif) Attached image(s) |
ahdoman |
Mar 7 2007, 06:43 PM
Thanks JB. I am not looking for something so race oriented. I had my retractor break and before I replace it I was looking to see what other harness options are out there. The bar type won't work because I am a tall guy and need to push my seat all the way back.
jasons |
Mar 7 2007, 06:54 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
There is this thing you can add to a factory belt that cinches it down like a harness.
http://www.cg-lock.com/ I mean if your belts broken, you still need a new belt. But if you want some more restraint out of your new belt this might help. |
Dave_Darling |
Mar 7 2007, 10:29 PM
Look at http://www.peparts.com -- they should be able to sell you a rebuilt seat belt mechanism.
--DD |
ahdoman |
Mar 8 2007, 08:51 AM
Look at http://www.peparts.com -- they should be able to sell you a rebuilt seat belt mechanism. --DD Thanks Dave. It looks like the rebuilds are a bit steep in price. I'd rather spend the extra money and get a harness. Anybody got any other ideas? Anything that doesn't use a harness bar? |
jr91472 |
Mar 8 2007, 09:01 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
I maybe a bit confused on what you are looking for. But if you just need new seat belts and don't want to pay for rebuilt 914 units, get a pair of either 944 or 924 units, they bolt on and are cheap.
I got a pair on ebay for $20. |
Dave_Darling |
Mar 8 2007, 08:54 PM
I'd rather spend the extra money and get a harness. Anybody got any other ideas? Anything that doesn't use a harness bar? The only ones that don't use a harness bar attach to holes drilled through the firewall. And they attach too low for most of us--they will cause spinal compression in an accident if they don't go back from your shoulders at close to a 90 degree angle! Very Bad News, that. Drop the dime (OK, 2000 dimes) and get the replacement stock belt. --DD |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:17 PM |
