> refinish a mirror?
rfuerst911sc
post Mar 10 2007, 02:21 PM
I recently purchased a OEM Porsche 914 exterior mirror and it's in great shape on all the metal parts. However the mirror itself has brown spots on/in it that need to be cleaned up? By brown spots I mean dark brown areas where it looks like the "mirror finish" is gone? Can this be repaired? If no can the mirror glass be replaced? Thanks guys (IMG:style_emoticons/default/beerchug.gif)
Replies(1 - 18)
Tobra
post Mar 10 2007, 02:26 PM
Glass can be replaced. I got some convex glass that Martin Baker had made up that I glued over the top of it. To replace the glass, you will probably have to get the plastic piece tha holds it in, which would be a neat trick. If you have about $110, you can buy a new convex glass mirror from the stealership
StratPlayer
post Mar 10 2007, 02:30 PM
StratPlayer
Yes the glass can be replaced, hard part is getting that trim piece around the glass out without messing it up. I usually start in one of the corners of the glass with a small screwdriver and gently get one of the corners of the trim above the mirror frame then work your way around the mirror with your screwdriver under the trim and it will come out. Take the glass to any glass shop and they will cut you a new piece.
markb
post Mar 10 2007, 03:34 PM
914less :(
How about an interior miror? I got one of the thin ones in the 71 I just picked up, and it needs a new morror.
Eric_Shea
post Mar 10 2007, 05:27 PM
PMB Performance
(IMG:style_emoticons/default/agree.gif) with Mr. Jim, Stratplayer. He came by and told me that he followed McMark's thread on the subject but I was a bit reticent about taking a screwdriver and prying on 30 year old plastic (black trim piece). But...
I did exactly as Jim mentioned and worked my way around. In less than 1 minute I had two pieces of raw glass in my hands. They were amazingly pliable.
Now... not "any" glass shop will cut you a new one. Jim, I tried Technia Glass here in town and they said only Central would do it. I just took my two glass pieces over to Central Glass yesterday. I thought it was kinda pricey at $15 each but... they'll be new and one might be convex. (IMG:style_emoticons/default/confused24.gif)
Anyway... Martin, if you're reading this, I opted to go this route and just get them done locally.
Want pics?
StratPlayer
post Mar 10 2007, 05:35 PM
StratPlayer
Eric there is a glass shop here in Sugarhouse that will cut all you need. I sent an extra piece to brant along with his mirror, the glass is great. If you need any let me know and I will get you some.
watsonrx13
post Mar 10 2007, 05:48 PM
Very interesting discussion. Here in Tampa, FL, I had an interior mirror that began to discolor. I removed the glass and took it to a local glass shop. They absolutely refused to cut me a mirrored glass. (IMG:style_emoticons/default/mad.gif)
I eventually found another interior mirror to replace it with....
Good luck...
-- Rob
rfuerst911sc
post Mar 10 2007, 07:14 PM
QUOTE(StratPlayer @ Mar 10 2007, 12:30 PM) *
stratplayer do you pry the trim piece up by placing the screwdriver between the glass and the trim? What holds the trim piece in? Are there locking tabs or something? I don't want to break it. Thanks
StratPlayer
post Mar 10 2007, 07:51 PM
StratPlayer
Pressure is what holds that trim piece in place. Just work a small screwdriver underneath the trim, once you get a corner of the trim up the rest will come easily.
Eric_Shea
post Mar 10 2007, 08:11 PM
PMB Performance
Too late... plus, if you do anymore shit for me I'll owe you my house or something! (IMG:style_emoticons/default/biggrin.gif)
(how much did they charge?)
StratPlayer
post Mar 10 2007, 08:19 PM
StratPlayer
They charged me about 20 bucks for 8 pieces.
Pat Garvey
post Mar 10 2007, 08:26 PM
Do I or don't I...........?
QUOTE(rfuerst911sc @ Mar 10 2007, 08:14 PM) *
Assuming you have measurements for the glass, wouldn't it be easier to remove the plastic retainer if you broke the glass out of it?
StratPlayer
post Mar 10 2007, 08:29 PM
StratPlayer
Yes if the glass is broken it makes removing the retainer much easier, still have to be gentle with it, its old, treat it with kid gloves. Remove all the broken glass first.
Johny Blackstain
post Mar 10 2007, 08:55 PM
AA sells replacement glass for mirrors... $26.95? Check the website & measure your mirror.
(IMG:style_emoticons/default/cool_shades.gif)
Eric_Shea
post Mar 10 2007, 09:11 PM
PMB Performance
Arrrrrrrrrrrrrrgh (IMG:style_emoticons/default/headbang.gif)
I'm gonna call Monday and see if they can stop the order!
StratPlayer
post Mar 11 2007, 11:00 AM
StratPlayer
Eric I'm sure I have a couple extra pieces of glass, I will give you a call, if I do and you can cancel the order I will drop the mirrors off to you.
rfuerst911sc
post Mar 11 2007, 04:32 PM
O.K. assuming I can get the trim piece off how do you remove the mirror?
So.Cal.914
post Mar 11 2007, 04:40 PM
"...And it has a front trunk too."
Just about anyplace that does custom mirror work will make the pieces. It
would not be that hard but labor intensive, round cuts that tight are near
impossable you have to machine sand the shape.
Eric_Shea
post Mar 11 2007, 08:23 PM
PMB Performance
Tip it over. (IMG:style_emoticons/default/huh.gif)
- Lo-Fi Version Time is now: 16th April 2026 - 02:09 AM
