> Jacking up rear, where should I put jacks?
DrifterJay
post Nov 27 2003, 12:20 AM
I break stuff...
Ok I am dropping the motor friday. Getting it prepped tonight, have removed trunk lid and engine lid to make things a bit easier for me. Where should I put the jacks in the rear, and where should I put the hydro jack when lifting? Jared (IMG:style_emoticons/default/wink.gif)
Replies(1 - 6)
Brad Roberts
post Nov 27 2003, 12:23 AM
914 Freak!
You can place them on the "donuts" or on the control arms if you have the tall 2 ton type.
If you use the control arms.. move them as far out to sides as you possibly can so the crossbar doesnt hit the stands when you drag it out with the engine.
Place the jack as far back on the engine as possible. Be prepared to "balance" the engine/tranny combo with the HE's or the HE support bracket.
B
DrifterJay
post Nov 27 2003, 12:25 AM
I break stuff...
what do u mean by HE?
Brad Roberts
post Nov 27 2003, 12:30 AM
914 Freak!
heat exchanger.
B
DrifterJay
I break stuff...
THANX I appreciate your help greatly. ttyl
sj914
post Nov 27 2003, 03:22 AM
You can also use put the jack stands underneath the rearmost of the floorpan. Position the jacks under the longitudinals and also use a long 2x4 to set across the jackstands to sort of cushion the chassis. I've used this method a couple times and its worked pretty well. Suspending the chassis this way also keeps the area clear so you don't have to worry about the engine bar getting caught on the stands. Sorry for the rambling but I just got in from pulling my engine out.
seanery
post Nov 27 2003, 07:58 AM
waiting to rebuild whitey!
I've seen creases on the floor/firewall area that looks like someone tried to pick up their car there. I wouldn't recomend that location.
- Lo-Fi Version Time is now: 16th April 2026 - 12:51 AM
