oil pressure light, on dash flickering |
jimkelly |
Mar 11 2007, 07:42 AM
i noticed that a wire going to the coil sends a signal to the light - is this correct or could this be my problem causing the flickering?? if i disconnect this wire the light goes out. jim
ClayPerrine |
Mar 11 2007, 07:46 AM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
i noticed that a wire going to the coil sends a signal to the light - is this correct or could this be my problem causing the flickering?? if i disconnect this wire the light goes out. jim If you are seeing that, then you need to put a mechanical oil pressure gauge on the car and check the pressure with it. If the readings are OK, then replace the sender. Otherwise you may need some engine work. |
TheCabinetmaker |
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Oil pressure light does not attach to the coil. It goes to a wire that will come out of the harness near the center of the case on the passenger side
jimkelly |
Mar 11 2007, 12:10 PM
i do not have my haynes with me and still have lots to learn - but my engine is a GA001xxx and off the harness that goes near the coil have a black wire that goes to the coil and a green/brown wire that (when plugged onto my coil) makes me oil pressure dash light blink wildly. if not to coil - where does this connect to. note: my car is a 1975 wiht a 1973/74 engine. thanks !!!
So.Cal.914 |
Mar 11 2007, 12:31 PM
It should be a green and red, I think, wire (old wire= red may look brown) it
should connect to the oil preasure switch. You will find it behind the dizzy (torwards rear of car) thru a hole in the sheet metal, only a few inches from your dizzy IIRC. |
jimkelly |
Mar 11 2007, 01:05 PM
ok - got it -- but -- sensor must have been previously sheared off - no top ha is there any other place on engine to get pre4ssure from ??
jim [quote name='So.Cal.914' date='Mar 11 2007, 10:31 AM' post='873348' It should be a green and red, I think, wire (old wire= red may look brown) it should connect to the oil preasure switch. You will find it behind the dizzy (torwards rear of car) thru a hole in the sheet metal, only a few inches from your dizzy IIRC. [/quote] |
So.Cal.914 |
Mar 11 2007, 01:09 PM
[quote name='jimkelly' date='Mar 11 2007, 12:05 PM' post='873370']
ok - got it -- but -- sensor must have been previously sheared off - no top ha is there any other place on engine to get pre4ssure from ?? jim [quote name='So.Cal.914' date='Mar 11 2007, 10:31 AM' post='873348' It should be a green and red, I think, wire (old wire= red may look brown) it should connect to the oil preasure switch. You will find it behind the dizzy (torwards rear of car) thru a hole in the sheet metal, only a few inches from your dizzy IIRC. [/quote] [/quote] Replace sensor with a new one, simplist fix for you. |
jimkelly |
Mar 11 2007, 03:13 PM
here it is...
Attached image(s) |
Aaron Cox |
Mar 11 2007, 04:07 PM
looks like a drill and EZ out operation?
i believe the thread is almost identical to 1/8 npt, |
So.Cal.914 |
Mar 11 2007, 04:10 PM
looks like a drill and EZ out operation? i believe the thread is almost identical to 1/8 npt, |
jimkelly |
Mar 11 2007, 04:11 PM
thanks guys : )
Aaron Cox |
Mar 11 2007, 04:12 PM
what did you coil's oil pressure look like BTW? (IMG:style_emoticons/default/smile.gif)
So.Cal.914 |
Mar 11 2007, 04:15 PM
About 10,000 volts PSI.
Aaron Cox |
Mar 11 2007, 04:16 PM
jimkelly |
Mar 11 2007, 04:20 PM
guess i am the first with an oil cooled coil : )
Aaron Cox |
Mar 11 2007, 04:24 PM
(actually, most coils do have oil in them .... shake one if you have one out.... unless it is epoxy filled for high vibration applications)
Brando |
Mar 11 2007, 04:36 PM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
About 10,000 volts PSI. (IMG:style_emoticons/default/lol2.gif) The higher your RPMs the more it would flicker eh? |
SLITS |
Mar 11 2007, 09:31 PM
About 10,000 volts PSI. (IMG:style_emoticons/default/lol2.gif) The higher your RPMs the more it would flicker eh? Just after the light turned solid the engine threw a rod! |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:05 AM |
