Fuel Line Size At Tank, Gonna pull it today |
Allan |
Mar 11 2007, 12:35 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I've decided that since I'm getting the car painted I might as well pull the tank and fresh air box and do it right. I do have some fuel in the tank and just need something to plug the fittings on the bottom so I don't end up with a lake of fire in the garage.
I'm going to replace the lines from the tank to the ones that run through the tunnel but can't remember which size. I seem to remember either 12mm or 5/16. I am running carbs so the high pressure FI lines aren't needed. |
sww914 |
Mar 11 2007, 12:39 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
I've decided that since I'm getting the car painted I might as well pull the tank and fresh air box and do it right. I do have some fuel in the tank and just need something to plug the fittings on the bottom so I don't end up with a lake of fire in the garage. I'm going to replace the lines from the tank to the ones that run through the tunnel but can't remember which size. I seem to remember either 12mm or 5/16. I am running carbs so the high pressure FI lines aren't needed. 5/16" 12mm is almost 1/2". I try to use the old German hose clamps again when possible, the US made ones are junk, IMHO. Good luck, I hope all is well with your project. Steve |
rhodyguy |
Mar 11 2007, 12:57 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
alan, 5/16 (8mm) is what i used. i broke down and bought a 25' box of Gates fi hose. i can use it for FI or carbs. per foot cost was the same as standard carb hose since i bought in *bulk*. next i'm going to put in one of chris' stainless lines so i can forget the center tunnel hassle forever. do you have to run a return line with your 6 fuel pump?
k |
Allan |
Mar 11 2007, 01:00 PM
Cap'n Krusty |
Mar 11 2007, 02:52 PM
5/16" is too big. 7mm is correct. The larger of the 2 lines is 9mm, and is the supply line. The smaller is 7mm and is the return. Neither is a "pressure " line in a 1974 chassis, as the pump was originally mounted in the rear. While FI hose is always desirable, even more desirable is the correct diameter! Were I choosing to eliminate one line, I would choose the smaller one, especially since the larger one has a debris screen ("sock") installed in the tank. So what you need is 9mm hose. Odds are the 8mm won't fit. The Cap'n
Tobra |
Mar 11 2007, 05:26 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
try a search, busdepot had some nice looking hose clamps, 7 and 9 mm hoses under there
PRS914-6 |
Mar 11 2007, 05:46 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
The actual fitting size coming out of my tank (72) is 8 and 10 mm. It's sitting on my bench right now.
Lo-Fi Version | Time is now: 23rd May 2024 - 03:37 PM |
