> Deflector, Is this needed
spunone
post Mar 12 2007, 02:44 PM
Had nothin to do Sunday afternoon decided to cut out rust in rear trunk.Now do I need I guess its a heat deflector thats under the trunk If i'm running headers?? Might as well keep cuttin stuff out at this point Thanks Paul
Replies(1 - 8)
dr914@autoatlanta.com
post Mar 12 2007, 02:57 PM
QUOTE(spunone @ Mar 12 2007, 12:44 PM) *
YOU NEED IT!!!!!!!
So.Cal.914
post Mar 12 2007, 02:58 PM
"...And it has a front trunk too."
As long as you are not going to put anything in the trunk that will be adversely
affected by heat, I'd say No.
spunone
post Mar 12 2007, 03:00 PM
Ok Doc I hear ya LOUD and clear It must get really hot back there is my guess
post Mar 12 2007, 03:24 PM
QUOTE(spunone @ Mar 12 2007, 01:00 PM) *
It would be great without the deflector to fry eggs!
My 76 has the deflector installed and actually burned the paint and the insulator.
Rand
post Mar 12 2007, 03:35 PM
Cross Member
If you care about it being stock, or you want to haul crayons and cheesecakes, then you need the heat shield.
If you like the idea of losing excess weight wherever possible and won't be hauling heat-sensitive items in the rear trunk (and no, it won't get hot enough to fry eggs), then lose it. This has been discussed before BTW, so there are a lot of comments on this in the archives.
The right answer for you depends on YOUR use of the car.
post Mar 12 2007, 10:49 PM
I like my eggs over easy, thanks!
(IMG:http://img.photobucket.com/albums/v520/bak535/Picture210.jpg)
So.Cal.914
post Mar 13 2007, 12:34 AM
What type of header and muffler are you going to use? If it is one with a super
trap and isn't even going to be in that area it dosen't matter. You would not be
the first to remove it.
Joe Ricard
post Mar 13 2007, 06:44 AM
CUMONIWANNARACEU
My 70 never had it. Been fine for all this time.
I now have a Tangerine and the trunk does not get as hot.
I used to put some insulation under my race tire to keep it from getting too hot. and the side wall.
- Lo-Fi Version Time is now: 15th April 2026 - 02:05 PM
