Engine and Transmission mounts, for a 76. |
blitZ |
Mar 13 2007, 07:21 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
My engine and transmission mounts have no rubber pieces, like I have read they should have. I'm going to get new mounts. I assume the rubber donut for the engine mount goes on top, above the mounting plate? I
The transmission mount is the same way, no rubber damper at all. I'm thinking of using JWest hard nylon mounts for the engine and the solid mounts from PP for the transmission, anyone else use these? Thanks |
BAM |
Mar 13 2007, 09:46 AM
Don’t sweat the small stuff !!! Group: Members Posts: 69 Joined: 10-January 07 From: SF Bay Area Member No.: 7,442 |
My engine and transmission mounts have no rubber pieces, like I have read they should have. I'm going to get new mounts. I assume the rubber donut for the engine mount goes on top, above the mounting plate? I The transmission mount is the same way, no rubber damper at all. I'm thinking of using JWest hard nylon mounts for the engine and the solid mounts from PP for the transmission, anyone else use these? Thanks Hi blitZ, I have sold and installed the JWest nylon mounts and have had nothing but good feedback… Regarding the Trans mounts, personally I am not a big fan of the solid mounts. I like to install 911 sport engine mounts and used them as 914 transmission mounts, also nothing but good feedback. Hope this helps. JP |
blitZ |
Mar 13 2007, 10:02 AM
I was looking at the 911 sport mounts also. Are the aftermarket brands as good as the OEM?
rhodyguy |
Mar 13 2007, 10:16 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,097 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if i read this correctly...for your 76', the engine mounts (039 199 231) are inboard on top (near the center) of the engine support bar. the front outside mounts are pieces of steel (914 375 181 00).
k |
Bleyseng |
Mar 13 2007, 10:19 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
The engine bar is bolted without any rubber at the ends to the chassis. At the engine behind the fan is two rubber mounts. Those do go bad and are cheap.
On the tranny mounts, some like the 911 solid engine mounts (sport) or the 914/6 ones. The 914/4 tranny mounts are not solid rubber and pretty soft so they fail the easiest. |
Lo-Fi Version | Time is now: 13th June 2024 - 01:11 AM |
