GEEKY progress thread, Because I just gotta |
Joe Ricard |
Mar 16 2007, 07:03 AM
Getting deck measurements. need a .212 shim
Them Waterboxer rods sure are long Attached thumbnail(s) |
bd1308 |
Mar 16 2007, 07:16 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
rick 918-S |
Mar 16 2007, 08:18 AM
Hey nice rack! -Celette Group: Members Posts: 20,492 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:style_emoticons/default/popcorn[1].gif) woooo that thing is gonna rev.... (IMG:style_emoticons/default/cool_shades.gif)
type11969 |
Mar 16 2007, 08:28 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
Joe-
When you bump the cylinders out that far, do you run into issues with the cylinders coming far enough out of the registers that they can move around radially in the registers? An engine I have been planning for a bit needs ~1/2 spacers if I run a certain combo and I seem to recall the area of the cylinder that mates into the block either having a taper or a step such that if I do pull them out that distance, they can move around. Maybe your cyls don't have this issue. Hopefully that question makes sense. -Chris |
Joe Ricard |
Mar 16 2007, 09:36 AM
Nope not a problem for this engine. I suppose thereis anissue witht too much shim.
Using Jake's Support I am going top make a REVIN little bastard. |
jd74914 |
Mar 16 2007, 09:49 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Are you using the stock head studs? Are they long enough to work? Did you need to make any modifications to the waterboxer rods to get them to fit into the 2.0 crank (if you are using that) . . . how about on the piston side?
It is looking good (IMG:style_emoticons/default/clap56.gif) |
Cap'n Krusty |
Mar 16 2007, 10:00 AM
1.9 or 2.1 rods? We in the Vanagon community have seen a LOT of 2.1 big end failures. In fact, I cancelled plans to make my own Vanagon a 2.1. The Cap'n
brer |
Mar 16 2007, 11:03 AM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
dude, those look sweet.
Aaron Cox |
Mar 16 2007, 11:05 AM
sexy pistons...
Joe Ricard |
Mar 16 2007, 08:42 PM
Type I big end with some sort of ARP "like" bolts. Type IV little end. Crank is modded for Type I journals.
Head bolts should be OK length wise won't know till I get the base shims. Got stuck putting Ohlins on an Audi A4 today along with bigger sway bars and seriuos ly stiff springs. 1200lb on the rear GEEZ that car is heavy. |
Aaron Cox |
Mar 16 2007, 08:46 PM
71 mm stroke?
they welded up the journals to type 1 size? or custom/new crank? |
Joe Ricard |
Mar 16 2007, 08:53 PM
Yup. makes 2098cc
Aaron Cox |
Mar 16 2007, 08:54 PM
what did the journal welding cost?
dude. this is gonna be a sick motor! |
URY914 |
Mar 16 2007, 10:16 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I've seen those P & C before. (IMG:style_emoticons/default/biggrin.gif)
Joe Ricard |
Mar 17 2007, 05:24 AM
what did the journal welding cost? dude. this is gonna be a sick motor! Crank was sourced from the mad man in Georgia. it's listed in his store. Also got the intermediate balance. and it is really sweet. Yea Paul lets just hope I got the skills to make use of them properly. (IMG:style_emoticons/default/driving.gif) Won't be a success till the car sits on the podium at a national event |
Joe Ricard |
Mar 21 2007, 03:55 PM
Piston dome is 8cc
Used Playdough. easy as can be. .172 sticking out + .040 negative deck makes for blanchard ground shim .212 equals static compression of 10.2:1 Tonight I am doing the end play and order all my shims at once. got a mock up 2.0L head to do push rod length one shims and stuff get here. |
Matt Romanowski |
Mar 21 2007, 04:02 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
who is blanchard grinding shims?
DerekKim |
Mar 21 2007, 04:21 PM
Member Group: Members Posts: 387 Joined: 27-August 04 From: Gulfport, MS Member No.: 2,635 |
"I wanna go fast!" Joe I think I want to buy your old motor. I'll talk to you when you come over Saturday.
Joe Ricard |
Mar 21 2007, 08:15 PM
I don't do financing. and it won't be cheap.
I might have spelled it wrong but it is the proccess Jake uses to machine or grind the shim perfect. |
DerekKim |
Mar 21 2007, 10:46 PM
Yeah just hold it until I go out and work off shore for a month or so!
Lo-Fi Version | Time is now: 8th June 2024 - 07:42 PM |
