| skline |
Mar 16 2007, 09:57 AM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I remember reading that someone makes a clutch tube repair kit but cant for the life of me remember who. The clutch tube is pulled in on this car and I want to do it now before I get things going too far. Where can I get one? Anybody know?
| skline |
Mar 16 2007, 11:25 AM
Ok, so nobody remembers it either, ok, what is the best way to repair a broken clutch tube? Any suggestions or ideas on what the best way to do it?
| Brando |
Mar 16 2007, 11:28 AM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Skliney, I had to do one at the shop. Weld'er up pretty much, and make sure the fuel lines are not nearby. Get some tube stock about the same size and we might be able to fab up a connection as well. The only non-welding trick I've seen was the one guy who used stainless wire and wrapped it through the tunnel, but that was a temporary measure.
| toon1 |
Mar 16 2007, 11:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
is it the tube itself or the standard, broken from the firewall,broken from the tunnel, situation??
| skline |
Mar 16 2007, 11:46 AM
They say "a picture is worth a thousand words" so here ya go.
| John |
Mar 16 2007, 11:55 AM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
On a repair like that one, I like using a 1/2" Fender washer with one side cut off to make a sort of D shape.
The flat would mount in the down position (where it would meet the floor seam) You may have to grind some other spots to clear everything, but it works well. I full weld the washer to the car and then tack the tube to the washer until it is a continuous weld. Inserting something into the end of the clutch tube helps prevent the weld from penetrating the tube and causing problems. In my BLOG, I show a plate with a 1/2"diameter hole drilled in it welded onto mine. Good luck. |
| skline |
Mar 16 2007, 12:21 PM
Well, thanks for the ideas, I will work on it today and expand a little with my own imagination. Brandon is on his way over to help with things so I will have his input as well.
Today I will pull the factory fuel lines out and get the tunnel all cleaned up and the clutch tube welded back in place and reinforce it properly and to my satisfaction. Progress pics coming later. |
| 914-8 |
Mar 16 2007, 12:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
As said above, get a large washer from the hardware store, cut it down to a D shape so it fits, and weld it up.
You also need to re-weld the tube in the tunnel, too, as those have undoubtely broken loose. They need to be fixed in place or the clutch won't work right. |
| ClayPerrine |
Mar 16 2007, 01:06 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Suggestion.... Hydraulic clutch kit.
contact Rich Johnson, he sells one that will work great. Or you can weld it back up. I would put a big reinforcement on the tube inside the tunnel. and weld that sucker back up in a few places inside the tunnel. (BTW... Betty's car has had a U clamp on the front of the clutch tube for more than 10 years now. It works fine, so I don't mess with it.) |
| Aaron Cox |
Mar 16 2007, 01:09 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
i told ya about the washer thing... but you can also do a bigger scab plate if need be....
you can do it. tell brandon to drop my head tool off at mi casa (IMG:style_emoticons/default/smile.gif) |
| messix |
Mar 16 2007, 02:01 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
if your gonna weld it, slip a copper tube inside the clutch tube to prevent the weld from blocking the tube. just tack stitch it at the washer to keep from melting the copper into a puddle.
| skline |
Mar 16 2007, 03:36 PM
i told ya about the washer thing... but you can also do a bigger scab plate if need be.... you can do it. tell brandon to drop my head tool off at mi casa (IMG:style_emoticons/default/smile.gif) He said he cant get to it until Monday since he is locked out of the shop. |
| skline |
Mar 16 2007, 03:38 PM
| John |
Mar 16 2007, 03:52 PM
In this picture, I used a larger piece of sheet metal (12 ga I think) as the area had been torn much like yours. I wanted a larger area to support the pressure on the clutch cable tube. The welds aren't much to look at, but they are strong.
| skline |
Mar 16 2007, 05:51 PM
Thanks John, that is perfect, I am going to go with a hydraulic setup but I still want it to be repaired so I will do it just like you did with the heavy steel.
This forum is great! |
| spunone |
Mar 16 2007, 05:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Scotty ya need some 12 gauge steel ?? give me a size and off it goes Cya
| skline |
Mar 16 2007, 06:33 PM
Scotty ya need some 12 gauge steel ?? give me a size and off it goes Cya Thanks Paul, I have a bunch here already I can cut up. What I really need is one of those louvered front trunk pieces (IMG:style_emoticons/default/smile.gif) |
| Joe Owensby |
Mar 16 2007, 07:04 PM
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Alternative fix. I had a similar problem with mine many, many years ago. I didn't have access to a welder in my garage, so as a "temporary fix" -
I removed the clutch tube ( it was loose at both the front and rear), and took it to the lab where I work, and had a piece of 3/16 inch steel (about 1.5 x 3inches) welded to the tube, similar to that shown in the photo above. I then drilled two 1/4 inch holes through the plate and through the firewall. Then I just bolted the tube back into place. Other than the two bolts, the nuts which are accessed through the removable plate inside the car on the tunnel, it looks similar to the photo. (added some sealant around the outside). At the front of the tunnel, I used a pair of conduit clamps that wrapped around the tube and bolted through the floorboard. I know this is not pretty, but it lasted over 100,000 miles after I did this, longer than the original tube attachment. I just recently replaced the floorpan due to rust elsewhere, and took advantage of having good access to put the clutch tube back to original. Joe |
| 914-8 |
Mar 16 2007, 07:25 PM
Are you just using the 901?
If so, why a hyd clutch? |
| ThinAir |
Mar 16 2007, 07:38 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
Here's how I handled the same situation. Classic Thread on Clutch Tube Repair
Lo-Fi Version | Time is now: 2nd April 2026 - 07:44 PM |
