Type 4combo 2270 ?, extra motor |
sixnotfour |
Mar 17 2007, 12:17 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
So I bought a roller, recognized it as a pelican car , this is the motor, any good?
should I take apart and part it or sell whole, has been sitting and some corrosion in one intake port , water ? Whats it worth together ? pieces? Thanks for your input; here is the description from the pelican build thread: specs on the motor, it's a 2270 comprised of a 78mm crank, lightened and balanced rods, 96mm balanced and lightened pistons weight balanced within .5 grams, a SCAT 275 duration X 490 lift cam and SCAT lube-a-lobe lifters, straight cut cam gears, high performance springs and dual 45 Dellorto carbs. If it were a six I would exactly know what it is worth being a type 4 , I have no idea , |
sixnotfour |
Mar 17 2007, 12:22 AM
It is oil film covered now, was removed to fix oil cooler leak and has sat since.
old thread; http://forums.pelicanparts.com/showthread....ighlight=skline Attached image(s) |
anthony |
Mar 17 2007, 12:48 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
It costs $5K to build up a 2270. The carbs are worth some money. I think if you get it running, compression, and leak down tested that you'll get top dollar.
messix |
Mar 17 2007, 01:36 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
oh god it's yellow!
it's not worth any thing. i'll be by tomorrow to get that out of your eye site, i wouldn't even feel right about asking for gas money to do it either, i'm just that nice of a guy. (IMG:style_emoticons/default/biggrin.gif) i'll trade you a proper black and oil stained 1,8l for it! |
Bleyseng |
Mar 17 2007, 10:42 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
What rods?
Switch out the cam/lifters to some Raby ones that will make power and last. Then its a really good motor that will last. Start it up and tune then sell it. Lots of motors were built during the bad cam period, is this one? |
rhodyguy |
Mar 17 2007, 11:08 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
well...the carb linkage is on backwards. do you know where the leak is? bring it down, add some plug wires and oil, plug it into the silver car and see how it runs. need any rhodys? i have LOTS to trade.
carbs not needing a renew including linkage-$300 to 400, heads (2.0)- the ones you saw fetched $300 (iirc). rods-maybe $100 prob less. 2.0 tin $100 to 130. did it come with heat exchangers? k |
sixnotfour |
Mar 17 2007, 01:07 PM
SSI's I took em , Has dave said linkage now , carbs off in a box, oil cooler I was told .
Rods ell if I know ? QUOTE lightened and balanced rods Scat lubealobe , good/ bad ? |
Bleyseng |
Mar 17 2007, 01:13 PM
ok, its a mystery motor then. Rod and piston combo plus the cam makes or breaks it.
I am not a fan of SCAT...lots of em eat themselves to death. |
rhodyguy |
Mar 17 2007, 01:31 PM
jeff, post a picture of the triad and i'll compare it to mine. if it's the newer version it's worth some dough. with the *unknowns* factor i think the value lies in the components rather than the engine as a whole. this is dependent on what else is still on the engine, ie thermostat, oil temp sending unit... what would you be satisfied in seeing out of this engine. call me if you want to.
k |
914werke |
Mar 17 2007, 02:44 PM
"I got blisters on me fingers" Group: Members Posts: 10,142 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
the vultures are salivating (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/biggrin.gif)
messix |
Mar 17 2007, 03:04 PM
[he thinks about it and wonders if the old L-jet could run on that long block?]
rhodyguy |
Mar 17 2007, 06:17 PM
sixnotfour |
Aug 8 2016, 03:11 AM
HAHA, just found this thread ,, I had Rich D. take the thing apart.. total POS...stock crank and rod, case line board with some over bore bearings and some not.....what a mess
r_towle |
Aug 8 2016, 04:53 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Resurrecting your own 9 year old threads?
sixnotfour |
Aug 8 2016, 07:35 AM
Resurrecting your own 9 year old threads? yes because Rich D, took it apart last summer2015 ...shiny POS engine ..filling in the blanks.. (IMG:style_emoticons/default/poke.gif) |
rhodyguy |
Aug 8 2016, 07:38 AM
Was this the engine out of the car Jon B bought in California?
sixnotfour |
Aug 8 2016, 07:49 AM
yes
doesn't the carbs and linkage look familiar ?? |
rhodyguy |
Aug 8 2016, 08:09 AM
Stromberg had a hand in that engine.
Dave_Darling |
Aug 8 2016, 12:40 PM
I'm not sure that's exactly what he had in that engine.... (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/stromberg.gif)
--DD |
rhodyguy |
Aug 8 2016, 12:46 PM
I know the story behind the car it came out of. Had I bought the car someone would have been behind bars or given an attorney serious money hoping not to wind up behind those bars.
Lo-Fi Version | Time is now: 10th June 2024 - 05:59 PM |
