I Think I'm in Trouble..., Can't believe I've never noticed this before |
kconway |
Mar 18 2007, 12:03 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
Nomex on, going in...
I've had my car a little less then a year and have driven it about 10 miles while I tinker with "known" issues. I've pulled the dipstick several times but only in a dark garage or after I had driven the car. I only really focused on how clean the oil was. I did note the level, but again, the car was hot when checked. Yesterday, the oil light came on...so I checked it PROPERLY and realized the level was half way up the dipstick...several inches above the second line. If the car had poor oil pressure, could a "PO" dump an additional quart or two in to get the oil light to stay off? Okay, lemme have it... |
herman maire |
Mar 18 2007, 12:46 PM
Newbie Group: Members Posts: 45 Joined: 3-January 07 From: canada Member No.: 7,419 |
Nomex on, going in... I've had my car a little less then a year and have driven it about 10 miles while I tinker with "known" issues. I've pulled the dipstick several times but only in a dark garage or after I had driven the car. I only really focused on how clean the oil was. I did note the level, but again, the car was hot when checked. Yesterday, the oil light came on...so I checked it PROPERLY and realized the level was half way up the dipstick...several inches above the second line. If the car had poor oil pressure, could a "PO" dump an additional quart or two in to get the oil light to stay off? Okay, lemme have it... putting more oil in it will not change the oil pressure..... too much oil can result in other problems but increased oil pressure will not happen. You might want to check your oil pressure sensor first, oh, and get the oil at the proper level. Good luck (IMG:style_emoticons/default/wavey.gif) |
jk76.914 |
Mar 18 2007, 01:59 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
remote change it's all frothed up? That could affect the oil pressure, if it's pumping a lot of air?
kconway |
Mar 18 2007, 06:19 PM
davep |
Mar 18 2007, 06:25 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
jk76.914 |
Mar 18 2007, 06:52 PM
remote change it's all frothed up? That could affect the oil pressure, if it's pumping a lot of air? Huh? Are you refering to the oil pressure sender? I have the extended hose on mine. Should have said- there's a change the oil is all frothed up. If the oil level is too too high, it gets blended by the cam, or even the crank, I suppose, and gets frothy. Lots of air in it. The oil pump is a positive displacement pump when it pumps liquids, but not gasses. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:17 PM |
