> cold start valve
sk8kat1
post Mar 21 2007, 11:01 AM
ok I am installing a replacement engine and going over the engine before I plop her in the teener and low an behold the fuel line to the cold start valve has been cut and I can't find an open spot for the line to go to ?! please help ...2.0L d jet
Replies(1 - 11)
Bleyseng
post Mar 21 2007, 11:10 AM
Aircooled Baby!
look at this pic
sk8kat1
post Mar 21 2007, 11:16 AM
QUOTE(Bleyseng @ Mar 21 2007, 09:10 AM) *
look at this pic
I can't tell where it leadfs to.. but it looks like there is a line going to the top of the fuel rail... it thought that was for pressure testing ?!
Bleyseng
post Mar 21 2007, 11:31 AM
Aircooled Baby!
The side with the FP has the rail with three outlets, battery side gets the one with the plug.
The center outlet goes to the cold start valve.
sk8kat1
post Mar 21 2007, 11:53 AM
QUOTE(Bleyseng @ Mar 21 2007, 09:31 AM) *
both my rails are the same?!
Bleyseng
post Mar 21 2007, 11:54 AM
Aircooled Baby!
If one has the screw in it, take it out and run the CSV line from it. (IMG:style_emoticons/default/w00t.gif)
sk8kat1
post Mar 21 2007, 11:56 AM
fuel pressure reg side..
jasons
Jackstand Extraordinaire
They are the same. Which ever one you use on the pass. side is hard to access because of the MPS. To test fuel pressure, you just disconnect the cold start line and put your pressure gauge on.
sk8kat1
post Mar 21 2007, 11:57 AM
well ok then... (IMG:style_emoticons/default/biggrin.gif)
sk8kat1
post Mar 21 2007, 12:27 PM
so will the engine will still run properly even witk out the cold start valve .. except at first start ... right?!
Rand
post Mar 21 2007, 12:42 PM
Cross Member
QUOTE(sk8kat1 @ Mar 21 2007, 10:27 AM) *
Yes. And even first start. It doesn't do anything at all unless it's truly cold (below 40 anyway). I don't have a CSV any more and my car starts fine at freezing temps.
sk8kat1
post Mar 21 2007, 01:02 PM
sweet!!! (IMG:style_emoticons/default/thumb3d.gif)
- Lo-Fi Version Time is now: 31st July 2025 - 03:34 AM
