Removing Sail Panel Trim? |
Heckler |
Mar 22 2007, 01:40 AM
Newbie Group: Members Posts: 46 Joined: 19-February 07 From: Los Angeles, CA. Member No.: 7,549 |
Need to prepare for painting, it's pretty obvious for all of it expect for the one on the side of the car at the bottom of the sail panel w/o breaking it? Am I missing the obvious?
Thanks! |
tomamafone |
Mar 22 2007, 01:49 AM
There's no "I" in Teener Group: Members Posts: 109 Joined: 7-January 05 From: Hollywood, CA Member No.: 3,414 |
as far as i know it's just held in with little springgy clips. pry it off gently with a flathead screwdriver. try to get as close to the clips as possible when prying. that'll decrese your chance of breakage. happy painting!
Heckler |
Mar 22 2007, 02:04 AM
as far as i know it's just held in with little springgy clips. pry it off gently with a flathead screwdriver. try to get as close to the clips as possible when prying. that'll decrese your chance of breakage. happy painting! Are the springy clips attached to the back side of the panel or are the going to fall somewhere...? |
tomamafone |
Mar 22 2007, 02:07 AM
they're attached to the metal strip by sliding in the end of the strip. you're safe to just pull em off.
autohausdolby |
Mar 22 2007, 02:57 AM
Member Group: Members Posts: 232 Joined: 12-September 06 From: Sheffield, England Member No.: 6,821 |
Anyone got a photo of a sail trim equipped car with the trim removed?
1970 Neun vierzehn |
Mar 22 2007, 10:36 AM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Pics with the vinyl removed during restoration......hope this can help.
Attached image(s) |
crash914 |
Mar 22 2007, 06:17 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
there is a nut under the fender that holds the spring thingy in place also...just took off mine...
JamesBernard |
Mar 24 2007, 02:27 AM
Member Group: Members Posts: 52 Joined: 8-February 07 From: Tigard, OR Member No.: 7,513 |
i'm in the process of replacing mine right now, and i had to just replace them. they're not that much money anyway.
and i'd get pretty pissed trying to get them off without bending them at all.. good luck though! |
RustyWa |
Mar 24 2007, 12:11 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
Can't you just reach up in the fender wheel, clean the crud from around the spring clip and pinch it closed with your fingers, then push it out? I think that is how I did mine, but it was a long time ago.
autohausdolby |
Mar 25 2007, 04:18 AM
That's great, thanks! What diameter are the fixing holes? Some genius has welded them up on my car.
watsonrx13 |
Mar 25 2007, 02:07 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
pfierb |
Mar 25 2007, 04:38 PM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
What are you painting the sail panels with ?
autohausdolby |
Mar 25 2007, 05:56 PM
Super, thanks!
watsonrx13 |
Mar 26 2007, 05:23 AM
Lo-Fi Version | Time is now: 8th June 2024 - 08:05 AM |
