Removing Throttle Cable Sheath, Cable Snapped, pulled it out, sheath still in tunnel |
Carlitos Way |
Mar 23 2007, 10:57 AM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Any ideas/suggestions?
TROJANMAN |
Mar 23 2007, 11:07 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
what part of the tunnel?
you should be able to lift the little plates and get a hand in there, or remove the shifter. if it is furter back in the firewall, then try and push the new one through towards the shifter, where you can get a hand in to remove the old one. |
Carlitos Way |
Mar 23 2007, 11:08 AM
what part of the tunnel? you should be able to lift the little plates and get a hand in there, or remove the shifter. if it is furter back in the firewall, then try and push the new one through towards the shifter, where you can get a hand in to remove the old one. IT's actually stuck in the firewall area. I can't push it. But I'll take apart the shifter and see if I can find it there. Thanks for the heads-up!!! |
TROJANMAN |
Mar 23 2007, 11:19 AM
I'm not really a rodeo clown, I just stayed at a Holiday Inn Express last night (IMG:style_emoticons/default/biggrin.gif)
Carlitos Way |
Mar 23 2007, 11:20 AM
I'm not really a rodeo clown, I just stayed at a Holiday Inn Express last night (IMG:style_emoticons/default/biggrin.gif) TMI |
Tobra |
Mar 23 2007, 02:02 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
how about pushing it through with piece of coat hangar?
Carlitos Way |
Mar 23 2007, 04:25 PM
Tobra |
Mar 23 2007, 10:18 PM
Sorry, I have not had all the plates off over the tunnel, I thought perhaps you could access it closer to the firewall.
How about a roto rooter deal, or is the tube too small for that? Maybe a guitar or piano string? I chucked a guitar string into an electric drill, threaded it into the sheath on a bug, spun the drill and withdrew to pull a stuck sheath out of a beetle one time |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:02 AM |
