where water coming from, e-brake area |
will |
Mar 26 2007, 11:03 AM
licensed to kill Group: Members Posts: 272 Joined: 14-December 05 From: rancho cucamonga, california Member No.: 5,276 |
everytime I wash my car, I noticed water soaking my carpet and floor around the E-brake spring inside the cabin. The water soaked the carpet behind the seat as well. where is the water coming from?
no water leaking from the rear targa seal nor side seal is good. any idea? |
DerekKim |
Mar 26 2007, 11:06 AM
Member Group: Members Posts: 387 Joined: 27-August 04 From: Gulfport, MS Member No.: 2,635 |
I was told the back window seal once. Might want to look at that. I had about an inch of water in my vheicle behind my seats once... ouch!
SirAndy |
Mar 26 2007, 12:30 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
any idea? Rear Window ... BTDT ... there was a thread here somewhere on how to take it out, clean up the thing and reseal it ... (IMG:style_emoticons/default/smash.gif) Andy |
So.Cal.914 |
Mar 26 2007, 12:54 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I don't know your car but I do know that rusting thru is very common at the
bottem of the firewall. Look behind backpad and while you have it off you can change the butel rubber used to seal the back window. You will need to remove the other targa bar pieces. |
will |
Mar 26 2007, 03:44 PM
where do I get butyl tape? homedepot?
do I have to remove the trims on the side where the seatbelt bolts to? The top trip must be remove. |
SirAndy |
Mar 26 2007, 03:48 PM
where do I get butyl tape? homedepot? do I have to remove the trims on the side where the seatbelt bolts to? The top trip must be remove. all trim needs to go, backpad needs to go, seats out (makes it *much* easier) ... buy the buthyl from a auto-glass shop, they have the right stuff. clean off old crap, clean thoroughly with alcohol or similar, then lay the buthyl bead starting at the top center of the frame, all the way around. clean glass as well, press glass firmly on buthyl, make sure it seals all around. this is best done with another set of helping hands ... (IMG:style_emoticons/default/smash.gif) Andy |
So.Cal.914 |
Mar 26 2007, 03:50 PM
where do I get butyl tape? homedepot? do I have to remove the trims on the side where the seatbelt bolts to? The top trip must be remove. Yes you will need to remove the side pieces. Home depot may have it but I would go to a glass shop, different sizes and better quality. |
Chris Pincetich |
Mar 26 2007, 05:56 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Rear window seal for sure! I use 2 towels up against the rear window on the outside to catch and soak up any car-wash water, then give this little area it's own TLC. My quick fix of black silicone from the tube along the interior bottom seal keeps out 90% of the water, but I still get in there to dry off the 10% that clears both the towels and the silicone corner gap. Gotta protect my NEW 1/2 floor pan = big investment! (IMG:style_emoticons/default/beerchug.gif)
rhodyguy |
Mar 26 2007, 06:04 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
don't cross the butyl at the top, lay it side to side, just touching. doubling over creates a high spot which can make the rest of the window difficult to seal and easy to crack when you try to seat it. 2 spacers are required at the bottom. most autobody supply stores will have the butyl in stock. my local one stocks the 3M brand. i found setting the window was much easier with an extra set of hands.
k |
Lo-Fi Version | Time is now: 1st June 2024 - 12:03 PM |
