Variable muffler options |
yarin |
Mar 26 2007, 09:35 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I'd like to go with a different muffler setup on my 914, ideally a muffler that allows me to switch between two modes (ie: ferrari 575m muffler as mentioned on this board)
I know there are other manufacturers that use a similar techonology, I couldn't find that much. But I believe Nissan started using them in 2000+ Altima and Sentra models. Right now I have a 4-2-1 header system running to a flowmaster muffler. It's just too loud for street use and I really doubt it will pass the dB requirements at limerock. While I would really like the Tangerine Evo II muffler it exceeds my budget. I'd like to keep it under $200 if possible. Any suggestions for an adjustable muffler solution? Or even a standard muffler? I know I'll have to create exhaust hangers and all the goodies. Thanks I attached a pic of the exhaust system before I installed it two years back. Alternative I have a 4-1 supertrapp which i'd like to avoid.. Attached image(s) |
Aaron Cox |
Mar 26 2007, 09:49 PM
i have a eurorace 4-1 header.... and i modified a single in single out bananna 911 muffler.
it has the twin tips that are basically a straight thru, and the stock exit quiets it down some. http://www.914world.com/bbs2/index.php?showtopic=63852 |
Ferg |
Mar 27 2007, 12:04 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Don't know if this helps or not, but the early 90's Twin Turbo Stealths and Mitsu 3000 GTVR-4's had two different exhaust settings. Both cars had 2 twin pipe exhausts(4 outlets total), and a sport and tour mode switch on the dash, I believe in tour mode only one outlet in each side was open, Sport opened all four. Its been a while since I owned one and that's from memory, but it may be worth checking out.
Ferg |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:32 PM |
