Rear Trunk Lid Problems, doesnt want to level out? |
JamesBernard |
Mar 27 2007, 05:38 PM
Member Group: Members Posts: 52 Joined: 8-February 07 From: Tigard, OR Member No.: 7,513 |
I'm finishing up restoring my little green 914, but theres a problem with the rear trunk lid.
The left side sits higer than the right side. The right side fits nice and snug but the left(drivers) side is about half an inch too high. How do you get them even? |
dr914@autoatlanta.com |
Mar 27 2007, 05:44 PM
914 Guru Group: Members Posts: 7,888 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I'm finishing up restoring my little green 914, but theres a problem with the rear trunk lid. The left side sits higer than the right side. The right side fits nice and snug but the left(drivers) side is about half an inch too high. How do you get them even? replace the trunk hinge pivot bracket. It is broken. |
markb |
Mar 27 2007, 05:46 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I'm finishing up restoring my little green 914, but theres a problem with the rear trunk lid. The left side sits higer than the right side. The right side fits nice and snug but the left(drivers) side is about half an inch too high. How do you get them even? replace the trunk hinge pivot bracket. It is broken. (IMG:style_emoticons/default/agree.gif) |
watsonrx13 |
Mar 27 2007, 07:04 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
JamesBernard |
Mar 27 2007, 07:27 PM
yeeppp
haha thanks guys man what would i do without this site haha |
JamesBernard |
Mar 28 2007, 12:12 AM
how hard is it to find one of those?
how much are they normally? Are they hard to replace? my 914 is all torn apart, now would probably be the right time to fix it |
Andyrew |
Mar 28 2007, 12:16 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Find one? 914 parts store have them... (AA has em.. just saw them..)
Hard to replace? Cut out the old one, weld in the new one.. Bout 25 for the part.. Know a welder? Andrew |
martinef1963 |
Mar 28 2007, 05:02 AM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
I have a similar problem w/ my front hood. The passenger side sits just a little higher in the front of the car.
I notice though that when I release tension on the spring it sits better, however, when I open the hood it doesn't really want to stay open, as well. When I say I release tension on the spring I mean: driver side spring set on second notch, passenger side spring set on 1st notch. Is this normal for a 30+ year old car? thanks, Nando |
bperry |
Mar 28 2007, 07:10 AM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
how hard is it to find one of those? how much are they normally? Are they hard to replace? my 914 is all torn apart, now would probably be the right time to fix it You may want to look at yours to see if it is broken or torn or if the welds just sheered off because it might be re-usable. If not, Tweeks has them for $1.99. Trunk Hinge Bracket Part #400-110 The style is slightly different from what is on my 74 because the bottom is rounded vs cut like the top, but it could be made match by simply cutting off the bottom. --- bill |
JWest |
Mar 28 2007, 07:29 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
You can get a fix, rather than a replacement, here.
krazykonrad |
Mar 28 2007, 09:15 PM
Senior Member Group: Members Posts: 1,128 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
I had the same problem and it was the weld that hold the bracket in was broken, not the actual bracket itself. A little welding and it was as good as new. If its broken, it probably means you're missing the rollers that go on the thingies, torsion bar, i guess that spring the trunk lid. go with the solid metal upgrades fro J West. the stock plastic ones break all the time. Konrad |
woobn8r |
Mar 28 2007, 09:43 PM
Senior Member Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
I think the smart money is on the "fix"... less BS! My $0.02 (-15% cause I'm Canadian) |
Chris Pincetich |
Mar 29 2007, 01:17 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I *can* weld, don't have the equipment, didn't like the look of the tight space to do the repair...yada yada.... installed my JWest hinge in about 30 minutes and it rocks. It can adjust if you make a bad measurement...try that with the welded one. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 4th June 2024 - 01:39 PM |
