Clutch release fork free play |
MiddleGACruiser |
Mar 29 2007, 08:03 PM
Hobbits? What Hobbits? Group: Members Posts: 115 Joined: 5-September 04 From: Porschenaire, GA Member No.: 2,694 Region Association: None |
I've just installed a new clutch and the fork has .525 inch free play. I've read it should have about a half inch but not over that and if it does I should shim the ball behind the fork. Is .525 too much and should I shim the ball?
Cap'n Krusty |
Mar 29 2007, 08:32 PM
.525" is pretty damn close to .500". However, the rule is if you cut the flywheel, you shim the pivot ball. Use a nice flat washer, like one of the ones on the diff cover studs. Thje Cap'n
LowGT |
Mar 29 2007, 10:00 PM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
If you put a one washer shim in there you won't be anywhere close to .5in anymore. One shim changes it quite a bit. I'd be very happy with the number you have now.
spunone |
Mar 30 2007, 08:03 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Just wondering how do you measure the free play?
MiddleGACruiser |
Mar 30 2007, 05:18 PM
Just wondering how do you measure the free play? I took the measurement with the transmission out of the car. You can do it in the car with the cable disconnected. Push the fork forward as far as it goes. I use a plunge micrometer, place it on the fork where the cable connects, set the plunger about 1 inch out then zero the mic. I push the fork to the rear and measure the distance it travels. |
spunone |
Mar 30 2007, 06:15 PM
Great Thanks gonna check mine this weekend before install
Lo-Fi Version | Time is now: 6th June 2024 - 02:56 AM |
