How much Curil K2 goop goes on case halves?, ...and a couple other questions... |
mike373 |
Mar 30 2007, 02:21 PM
Member Group: Members Posts: 198 Joined: 3-August 05 From: san diego, ca Member No.: 4,536 |
Ok.... getting to the stage of actually putting stuff back together. How much Curil goop goes on the case halves.... and what should it be applied with? Also.... What should I use to seal the threads on the cylinder studs when I put them back in?? I have Loctite 565 PST for the case plugs... is that the same as standard Loctite 565??? Or did I buy the wrong stuff?
Thanks, Mike |
blitZ |
Mar 30 2007, 03:22 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I put a pretty thick bead on both halves and spread it with my finger. I used Permatex thread sealer, IIRC, I think that is what Jake's video suggested.
So.Cal.914 |
Mar 30 2007, 06:52 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
It depends on who you talk to, I clean the mateing surfaces where I would eat off
of them, then I apply a thin even coat of sealer on one side only. |
Allan |
Mar 30 2007, 06:56 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I didn't even know about the Curil goop when I rebuilt my motor and used Permatex 3M.
Granted, this was the original Jake video but, it held well and the only leak I had after 1000 miles was the tranny... |
Aaron Cox |
Mar 30 2007, 07:18 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
I didn't even know about the Curil goop when I rebuilt my motor and used Permatex 3M. Granted, this was the original Jake video but, it held well and the only leak I had after 1000 miles was the tranny... (IMG:style_emoticons/default/agree.gif) i used permatex 3h aviation sealant also... no leaks yet. 40k on the clock. |
Lo-Fi Version | Time is now: 7th June 2024 - 03:48 AM |
