Full CV Replacement, Both joints on both axles. |
McMark |
Mar 31 2007, 03:26 AM
Well, I fixed my blowed up CV today. WHAT A PITA JOB! I feel like I took a grease bath. (IMG:style_emoticons/default/barf.gif)
Thanks to Andy for helping me disassemble, clean and put new joints on my spare axles. After he left, I spent the next 5 hours fighting everything. (IMG:style_emoticons/default/rolleyes.gif) But now all I have to do in the morning is torque the bolts and I'm back! I also fixed my sticky brake caliper. The e-brake arm was sticking, so a little penetrating oil got it working again. Andy and I pushed my car across the parking lot, with the ebrake stuck on. (IMG:style_emoticons/default/pinch.gif) |
Gint |
Mar 31 2007, 09:09 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I *HATE* doing CV joints. Messiest job on a 914.
JPB |
Mar 31 2007, 09:16 AM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Did ya get doctor evil's bolts? Not a bad idea on new parts which should last a while or until the bolts work free and then bling blang srack squeeeeeeeeeeeel!
Eric_Shea |
Mar 31 2007, 09:26 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE The e-brake arm was sticking, so a little penetrating oil got it working again. That will ruin that seal (the one directly underneath the handbrake arm). The penetrating oil will swell the seal. Usually the reason the seals stick is because there's some rust in there. |
McMark |
Mar 31 2007, 10:08 AM
Thanks for the heads up Eric. I'll keep an eye on it. They're due for a rebuild anyway.
Eric_Shea |
Mar 31 2007, 10:44 AM
It's actually fairly common. A lot of people use a penetrating oil on an old caliper to help loosen things up. It works... for a while. I can't say I wouldn't do the exact same thing. It simply makes sense, except, there is that rubber seal in there. (IMG:style_emoticons/default/biggrin.gif)
Here's some photographic evidence. People even do it on "new" calipers as preventive maintence "Hey, I'll just spray some WD-40 in there to make sure it's lubed up." This is a caliper that came in for warranty work with that problem. (IMG:style_emoticons/default/wink.gif) Not good. Attached image(s) |
914werke |
Mar 31 2007, 11:11 AM
"I got blisters on me fingers" Group: Members Posts: 10,116 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Mark did you find that the spines above the circlip were rounded? I agree what a messy bitch! (IMG:style_emoticons/default/headbang.gif) Did ya get doctor evil's bolts? Not a bad idea on new parts which should last a while or until the bolts work free and then bling blang srack squeeeeeeeeeeeel! You know in more than ten cars owned Ive never encountered that problem, just make sure good schorer (sp) washers are under them and your good! |
Dr. Roger |
Mar 31 2007, 02:22 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Mark,
I have a set of Dr. Evil's CV bolts if you would like them. He does nice work. Sell 'em to you for what I got em for. =-) You know I went 911 and can't use them. |
McMark |
Mar 31 2007, 10:09 PM
I've got two sets on the shelf. (IMG:style_emoticons/default/wink.gif) Thanks Roger. I just used the stock bolts. Dr. Evil's bolts are great peace of mind, but not mandatory, IMHO. New bolts and new washers keep 'em in line. When you start reusing bolts and washers is when you get a problem. Oh, and fresh gaskets are a must as well.
I'm done now, and it's back on the road. I also swapped in the 19 mm sway bar while the car was in the shop. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:07 PM |
