wheel weights?, good AX wheel? |
sean_v8_914 |
Apr 6 2007, 09:50 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
are Pedrinnis OK for AX? are they lighter than Fuchs?
does anyone have wheel weights? |
Dave_Darling |
Apr 6 2007, 10:23 AM
Stock four-lug wheel weights (limited sample size) --
Fuchs == 13 lbs Mahles == 14 lbs Pedrinis == 17 lbs The Fuchs are the lightest of the stock four-bolt wheels. --DD |
gopack |
Apr 6 2007, 11:30 AM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
I always found this to be a good site for wheel weight questions. SOmeone spent a lot of time and effort compiling this database!
wheel weight data base (IMG:style_emoticons/default/biggrin.gif) not much for porsche OE wheels, much less 914, but interesting none the less! |
jhadler |
Apr 6 2007, 01:15 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
If you're looking for the best of what you can scrounge? Or the best of what you can get?If you're looking to shave the most weight, and price (and appearance) are secondary concerns, look at custom fabricated racing wheels.
Keizer, Real, CCW, Fikse etc. They won't be super cheap, but they will be a good deal lighter than even the fuchs. And, you can get 'em in pretty much any size you want (in case you aren't running in a "Stock" class). -Josh2 |
sean_v8_914 |
Apr 6 2007, 01:23 PM
thanks Dave.
I did not want to hear that. I'm not overly fond of Pedrinni's looks but since they are so heavy, I guess they will be for street use now Fuchs will wear RA-1s and the V700s Pedrinnis will wear the Falkin Azinis do you have weights for rivieras? |
alpha434 |
Apr 6 2007, 08:18 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Stark MS Forged 14x5 7.3lbs
sean_v8_914 |
Apr 7 2007, 02:18 AM
I run in CS
C+2.0 S= stock |
Tobra |
Apr 7 2007, 07:54 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Check the Fuchs for cracks very closely
sean_v8_914 |
Apr 7 2007, 12:41 PM
I check them before EVERY event.
that is a good warning, thanks. teh Pedrinnis look stronger but all that extra weight cant be good. my car is teh sum of all teh finest parts found in back yards across California. some day if I stop my CSOB ways, I might buy some really nice Fikse 3 pc customs for my V8 car, although I have been eye balling some mini lites |
Lo-Fi Version | Time is now: 10th June 2024 - 01:14 AM |
