timing indicators on fan, 1.7 and 2.0 are same? |
shaggy |
Apr 6 2007, 11:02 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
well are they?
-jim |
Aaron Cox |
Apr 6 2007, 11:16 PM
bd1308 |
Apr 6 2007, 11:45 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
i love delay
shaggy |
Apr 7 2007, 01:19 AM
so is that a yes or a no?
i dont own a timing light i borrow one and i have no clue what it is. |
alpha434 |
Apr 7 2007, 04:37 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
I think the better question is "how many different friggin fans are there?"
I've held three different ones in my hands for the 914. That doesn't mean that there aren't more. It all depends on the bolt pattern on the crank, and it's position in relation to TDC. If you have a non-stock crank. Or a difference between a 1.7 and 2.0 crank, it's likely that they are different. And who knows? There could've been a new guy in the crank department at the VW factory that day, and he screwed up the angle of the fixture on the turret lathe, that day. Changing a fan to pass some cranks is much cheaper than scrapping a crank because it doesn't match a fan. End story- don't even bother with the timing marks on a fan. Unless it's the same fan that came with your engine (factory inspection certified.) Use delay timing. |
Dave_Darling |
Apr 7 2007, 06:44 PM
And how exactly is delay timing supposed to help if the fan is not in the same orientation, so the TDC mark is all wrong? Honestly, Alphie, you should put a little more thought into things....
Stock 1.7 and 2.0 timing is the same. The stock timing marks are the same. There may be "extra" marks on some. The 1.8's timing was set differently, so it will have a different mark. Ditto the Bus engines; the timing was different so the mark will be different. Pelican has a Tech Article that tells you where the marks go. The stock fans and cranks have the same bolt holes and "in theory" are indexed the same. In reality, some of the fan castings are a little "off" in relation to others. You can see an example of that in Pelican's 914 timing tech article. Happily, it's still close... --DD |
Lo-Fi Version | Time is now: 1st June 2024 - 10:34 PM |
