removing window tint, how? |
TheCabinetmaker |
Apr 15 2007, 10:48 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Friend just bought a 86 carrera targa. the rear window is tinted. How can you remove the tint without damaging the defogger wiring? I know from personal experience that lacquer thinner and such will not touch the glue.
Thanks, Curt |
So.Cal.914 |
Apr 15 2007, 11:23 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I can tell you one way, Add a small amount of soap to a squirt bottle 3/4 full of
water. Keep the tint moist while you do this. With a razor blade in hand between your thumb and two of your four finges, start at the top, hold the razor at about a 30 degree angle, and with light preasure start to cut. As you draw the razor down cut in a 'S' pattern, now not as tight as an 'S', more like a snake all the way to the bottom. Make sure you keep it wet, this is the lube. Three 'S' cuts should do. Once you have these done use the razor to lift the edge at the beginning of the cut and peal the film away from the window. It will leave the glue in most places but 'Goo Gone or 'Goof off' will remove the glue. The Goof off is smelly so make sure if you use it to have both doors open and take fresh air breaks. I would sudjest you cover the interior below the window. |
TheCabinetmaker |
Apr 15 2007, 11:36 AM
Won't that damage the defroster wiring?
So.Cal.914 |
Apr 15 2007, 11:47 AM
Thats why you are holding the razor at such an extreme angle and with a light
touch. It gives you more of the film to cut into, and only the film. Make sure you keep it moist. Start your cut at the top where there are no wires and deep enough there to be able to lift the film with the razor after the cuts are done. |
jasons |
Apr 15 2007, 01:01 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Easiest way, and I learned this from a tint pro. Mix ammonia 50/50 with water. Spray the mix on the inside of the tint (inside the car). Put a black garbage bag on the window (inside the car again). The ammonia mix will hold the bag there. Let it sit for about 20 minutes in the sun. Take the bag down and then the tint will almost just lift off with no effort. I've done this 2 or 3 times and it works great. No need to scrape much at all. Some adhesive will remain, but the ammonia mix will clean it up.
Now you know why Windex ruins tint. |
So.Cal.914 |
Apr 15 2007, 05:14 PM
Easiest way, and I learned this from a tint pro. Mix ammonia 50/50 with water. Spray the mix on the inside of the tint (inside the car). Put a black garbage bag on the window (inside the car again). The ammonia mix will hold the bag there. Let it sit for about 20 minutes in the sun. Take the bag down and then the tint will almost just lift off with no effort. I've done this 2 or 3 times and it works great. No need to scrape much at all. Some adhesive will remain, but the ammonia mix will clean it up. Now you know why Windex ruins tint. If you go this route, be careful, the ammonia can discolor the interior. Covor things up. |
Matt Romanowski |
Apr 15 2007, 07:16 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
The amonia mix works better, but you can just use amonia glass cleaner. Soak the window inside big time and let it sit for 20 minutes and you can pull it off. You should be able to get all the glue. They also make plastic razor blades for detail shops that you can use on teh window.
Jenny |
Apr 16 2007, 11:43 AM
Advanced Member Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None |
Ditto on the ammonia mixture. Works really well. There will be some glue residue left on the glass after you peel off the film. What we always did at our shop after removing the film was spray some dawn/dish soap and water mixture, then scrub lightly with steel wool in circular motion (wax on, wax off). Takes off all the glue, leaves the defroster stripes intact. Good luck!
Jen |
effutuo101 |
Apr 16 2007, 11:47 AM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
I live in the NW where sun is limited and the Heat is not on yet. Will a hair dryer on the outside produce the same results? I have 1 window that is foggy (and has been since I bought the car)
jasons |
Apr 16 2007, 12:07 PM
I live in the NW where sun is limited and the Heat is not on yet. Will a hair dryer on the outside produce the same results? I have 1 window that is foggy (and has been since I bought the car) I don't know how critical the sun thing is. I live in AZ so its a no brainer. Do a google search and see what you find. I'm sure there is an answer somewhere. |
Jeffs9146 |
Apr 16 2007, 05:30 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Take the window out and soak it in the above mentioned Amonia mix in a plastic bag for as long as needed. Replace the rubber window gasket and clean up any rust that you encounter!
Do it right the first time and you won't have to do it again!! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:40 AM |
