Oil tank installation steps |
bcheney |
Apr 18 2007, 10:24 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
I have a OEM 914/6 Oil tank that I need to install into my conversion project. The car is a 75. Can anyone provide step by step instruction on how to install the tank? Just want to know the steps from someone who has completed this work so I can avoid mistakes. I have the 914/6 conversion guide from Auto Atlanta. However, it simply tells you to use the template they provide and install.
SLITS |
Apr 19 2007, 03:06 PM
Drill holes ..... slide tank in
make sure you angle the suction hose slightly towards the engine bay or it will hit the rocker panel. Oh yeah, put this hose on as you will not be able to get to it when the tank is installed. Also on later models ('73 up), there is apparently a piece of metal (seam) near the door striker plate on the inside of the fender well that may need grinding flush as it will interfere with the tank fully sliding into the fender well. I dunno, I converted a '70. Get a GOOD set of hole saws .... Harbor Freight's dulls the minute it touches metal. When you return them they tell you it is not for metal .... box dona say that. If you've drilled all the holes in the right places, ain't no thang! |
736conver |
Apr 19 2007, 03:36 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
I have a OEM 914/6 Oil tank that I need to install into my conversion project. The car is a 75. Can anyone provide step by step instruction on how to install the tank? Just want to know the steps from someone who has completed this work so I can avoid mistakes. I have the 914/6 conversion guide from Auto Atlanta. However, it simply tells you to use the template they provide and install. All the places you need to drill out are already stamped into your car, it should make it even easier with the template you have. Its just a matter of getting the right sizes for the hole saws. The bottom hole saw for the oil filter is going to be pricey. Maybe someone here has it that you can borrow. I know mine is out on loan right now. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:40 AM |
