What is the story on the Factory Windshield Seal?, Are there more coming? |
burton73 |
Apr 21 2007, 09:44 AM
burton73 Group: Members Posts: 3,539 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
As these are items that a lot of cars need what is the true story. I want a new one for my restoration and I do not want to get caught in the bull shit like the targa seals.
Who is in the know? Bob |
SLITS |
Apr 21 2007, 09:49 AM
Vellll, vee musz conzult die krystal ball.
Ver ist die krystal ball? Ach, der Frogs hasz gestollen es. Obviously, I don't know and I don't think Porsche does either. |
SLITS |
Apr 21 2007, 11:45 AM
PS .... I used the one out of a 911 ..... little wider than the 914 so it doesn't fit around the vents correctly (that's what Xacto knifes are for), but then I'm not a CW.
burton73 |
Apr 21 2007, 01:20 PM
Paul,
I take it if you are painting and changing your cars color you are going to need this to be changed as well as the metal trim needs to be re-placed at the same time. This is on a 1970. Using the Xacto with fresh blades, is the result good? Last what is a CW? LOL Fender cowl bead? Use cut 911? Thanks. Bob |
Toast |
Apr 21 2007, 01:29 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
Ron here ....
Fender cowl rubbers are available I thought you were talking about the seal that goes between the windshield and dash which is supposedly NLA. Not really a seal, just trim to cover the gap. Changing colors would not require renewal of the seal if you just pull the brite trim from around the windshield and paint the car. The look is just ok ... hey I used a used one 'cause it was laying there when I put the windshield in. A new one might look better. CW = Concours Weenie = Ferg = (IMG:style_emoticons/default/stirthepot.gif) Oh well, back to my 4/20 celebration (IMG:style_emoticons/default/smoke.gif) :insertUpinSmokerolledjointhere: And those ain't my boobs in the avatar ... mine are bigger |
StratPlayer |
Apr 21 2007, 04:31 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Inquiring minds want to know, who's boobs are they?
burton73 |
Apr 21 2007, 07:18 PM
Hate to be lame( but I cannot help myself) , but if you pull the bright and pull the windshield and want to renew the rubber can you get that windshield seal that holds the glass in and the bright trim in. Hate to be a CW but in some areas it is needed. Can the rubber be had?
Thanks, Bob |
Allan |
Apr 21 2007, 07:21 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Hate to be lame( but I cannot help myself) , but if you pull the bright and pull the windshield and want to renew the rubber can you get that windshield seal that holds the glass in and the bright trim in. Hate to be a CW but in some areas it is needed. Can the rubber be had? Thanks, Bob The glass is just held in with butyl tape ('70's ya know). The clips for the chrome trim are available fron any of the common suppliers. |
burton73 |
Apr 21 2007, 09:11 PM
Allan,
Are you saying that there is no window channel rubber like on a 911 holding in the windshield? So how do you remove the front windshield? No rope no trick tools? I look at the search area. Thanks, Bob |
burton73 |
Apr 21 2007, 09:29 PM
I found it in the search area I think under: Windshield is in. Rubber seal and black border
Thanks, Bob |
BigD9146gt |
Apr 21 2007, 11:14 PM
OCD member Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
Bob, it really depends on who was allowed to "fix" these cars over the past 30yrs. I've talked with several professional auto glass guys who argued with me over and over about how these windshields should be neoprene/rubber glued in... The factory used the butyl tape because it was cheap, sealed well, but most importantly stretched enough to keep the windshield from cracking due to chassis flex. Since these are targa tops, the windshield frame isn't structural like a coupe, so the windshield doesn't add any strength.
Cheers, Don |
SLITS |
Apr 22 2007, 12:09 AM
A couple of things ...
It takes a tool, bought or handmade, to cut the buytl rubber seal to get the windshield out. Many crack it trying to work the wire thru a corner so they can saw thru the buytl. Buytl rubber comes in tubes and tape form. I use 3/16" butyl tape and stretch it while installing it on the windshield frame. If you ditch the britework and go to the rubber trim that is commonly sold ... it does not stick the window in the frame. You still have to use the buytl rubber to seal the windshield. I did the rubber trim thing. Ok ... |
Gary |
Apr 22 2007, 12:14 AM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
I need to redo mine (frustrating) because the shop that did resto/paint for me didn't replace the clips for the trim. Also didn't replace the original dash-windshield seal. If you're doing this job, when you pull the windshield, get a new dash-windshield seal. I don't think it can be replaced with the windshield in, certainly not easily. Replace the trim clip holders, THEN put in the new butyl seal, windshield, and trim.
BigD9146gt |
Apr 22 2007, 01:25 AM
In the past, I grab two needle nose pliers and some thin wire (like bailing wire, piano or guitar wire works best) and poke one end through the butyl tape in either of the lower corners of the windshield. Then grab/wrap the wire with the pliers and carefully drag/cut up, across the top, and down the other side. Then push the top of the windshield out and this will break the bottom seal by leverage.
I've had lots of success with this, just be weary of applying too much pressure on the edge of the glass, imperfections on the glass's edge will snag the wire and cause cracks. Cheers, Don. |
burton73 |
Apr 22 2007, 02:00 AM
In West L.A. there has to be some good glass people that can come out and do this job right. This is one of the ones I do not want to dick with. Dons idea sounds easy. If I screw it up what the hell. it is only money. I need to see if the glass is premo anyway.
Thanks, Bob |
watsonrx13 |
Apr 22 2007, 07:20 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
In the past, I grab two needle nose pliers and some thin wire (like bailing wire, piano or guitar wire works best) and poke one end through the butyl tape in either of the lower corners of the windshield. Then grab/wrap the wire with the pliers and carefully drag/cut up, across the top, and down the other side. Then push the top of the windshield out and this will break the bottom seal by leverage. I've had lots of success with this, just be weary of applying too much pressure on the edge of the glass, imperfections on the glass's edge will snag the wire and cause cracks. Cheers, Don. Don, I've tried to remove 2 windshields using the wire method, but everytime I've cracked them. It appers that the cracks are around/under/near the clips, am I suppose to remove the clips first? If so, how do I do it? Also, when reinstalling the windshield, do the clips go in first, then the butyl tape, then the glass? -- Rob |
dr914@autoatlanta.com |
Apr 24 2007, 10:09 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
BREAKING NEWS!!!!!!! (and an apology)
I have finally gotten to the bottom of the windshield top seal controversy and have a PORSCHE factory guarantee of 100 plus top seals on the way. Everyone who has ordered one for the special price will get one, but in two or three weeks. I have gone through h.ll after placing our confirmed order and being invoiced from Porsche for something that did not exist. What the problem was is that there was a miscount in the inventory that resulted in a non existent inventory and the resultant delay in resupplying and reinventorying them. Behind the scenes I called my contact deep in the Porsche parts organization (my brother Peter's best friend) and he sheepishly admitted that there had been a miscount and that actually they had not sold that many of them in the last two months since a small number of them had arrived in the U.S. Well feeling like a fool to believe the word of Porsche and really not believing it until I verified five times, getting my shipping confirmation and my bill (previously posted) I had our buyer Bruce make a bunch of calls, and I too called people we knew in the organization. I immediately rounded up five of the seals, (all new stock) had my friend Michael Mittle in Germany send me 30 more and FINALLY had my brothers friend expedite the shipment from Germany for 100 more immediately and 100 additional in two to three weeks. I am very very sorry that this has happened. We have always been able to depend on Porsche for instantaneous delivery as we are one of their drop ship customers and are only about ten miles from the warehouse, and six from Headquarters. Please again my sincere apologies to the club. EVERYONE who ordered one will get one at the price, and I will post some pics of the seals and the confirmations as they arrive. If ANYONE feels like personally abusing me for this, please feel free to call me personally and vent: 800 792 4944 ext 16 business 404 308 5652 cell 770 971 4960 home. |
jasons |
Apr 24 2007, 10:28 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Does this mean there are more available for pre-purchase than previously planned?
TROJANMAN |
Apr 24 2007, 11:02 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Apr 24 2007, 12:01 PM
When I am able to put my finger in the hole and my hand in the side of the first 130 of these seals that we have immediately coming, it is then and only then that THIS Thomas will feel confident to make an additional offer to the club.
Lo-Fi Version | Time is now: 3rd June 2024 - 10:54 AM |
