Starting Woes, Double Check my list |
addwestern |
Apr 21 2007, 08:13 PM
NorCal Parts guy Group: Members Posts: 314 Joined: 21-June 06 From: Sacramento Member No.: 6,276 |
I am having an issue on my 73 2.0 with the starting system. Car gets power, and battery is strong. When turing the key- I get absolutely nothing- not even the momentary pulse to the fuel pump.
At first, I thought it may be the ignition switch, replaced that with new as well as checked the starter- can jump the poles and get it to crank. At this point, I have replaced the switch, checked the starter, and tried a new combo of board, regulator, and relays- to no avail. Anyone think of what I may have missed? (IMG:style_emoticons/default/headbang.gif) Thanks-Nate |
ahdoman |
Apr 21 2007, 10:06 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Hey Nate,
Careful with the relay replacement / testing. I recently discovered that it is possible to put the relays in 1 pin off (about 1/8 of a turn). I had problems getting my fuel pump relay to work and on a whim I pulled the relay, turned it one pin and it fit as well. When I did that all worked as it's supposed to. Just a thought. |
rhodyguy |
Apr 21 2007, 10:20 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
new starter.
k |
addwestern |
Apr 21 2007, 10:28 PM
I'll check that- a different starter also did no good- had that one in house.
addwestern |
Apr 21 2007, 10:32 PM
Hey Nate, Careful with the relay replacement / testing. I recently discovered that it is possible to put the relays in 1 pin off (about 1/8 of a turn). I had problems getting my fuel pump relay to work and on a whim I pulled the relay, turned it one pin and it fit as well. When I did that all worked as it's supposed to. Just a thought. I'll check that- a different starter also did no good- had that one in house. That worked on the fuel pump- I think I'll try yet another starter tomorrow. Thanks!!!! |
rhodyguy |
is this an all the time issue or when the car is good and hot?
k |
addwestern |
Apr 21 2007, 10:56 PM
I've only had the car about 2 months, but has seemed to be an intermittent issue both when the car is cold, and hot.
r_towle |
Apr 21 2007, 11:13 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Ground strap from transmission to under side of trunk.
I think on 73 there is a "logic circuit" under the passengers seat that will not let you start unless your seatbelt is fastened. This little box was a dismal failure due to lots of reasons..but location and rust had alot to do with its failure.. anyways, its part of the ignition circuit. Simple to fix. There are two very large yellow wires going into this little "box from hell" logic circuit. Remove them from the little silver devil and connect them together, away from the box. These are 12 hot leads, so do a good job wrapping them up so they never hit the ground... Rich |
addwestern |
Apr 21 2007, 11:21 PM
Nope- non-existent- (at least in this car)
SirAndy |
Apr 21 2007, 11:38 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Ground strap from transmission to under side of trunk. (IMG:style_emoticons/default/agree.gif) check your grounds ... |
addwestern |
Apr 22 2007, 12:49 AM
Ground strap from transmission to under side of trunk. (IMG:style_emoticons/default/agree.gif) check your grounds ... Yeah- that's about what I was figuring- there's the ones by the lights, trans strap, battery and by the relay board- right? |
r_towle |
Apr 22 2007, 11:22 AM
well realy for the starting circuit there are two grounds you need to worry about.
The ground strap to the transmission, and the ground strap from the battery to the body. rich |
drive-ability |
Apr 22 2007, 08:18 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I would think the ground by the fuse / relay board is vital, just seems to me I am no 914 systems expert however
914nerd |
Apr 22 2007, 10:13 PM
Who you callin' a "Member"? Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 |
fuel injected?
if so, the FI relay is a critical part Do you have fuel? Spark? Starter? Check them all individually and (with a current flow diagram) look for common connections that might have failed |
Lo-Fi Version | Time is now: 8th June 2024 - 06:30 AM |
