TINCAN914 |
Summer's Commin... ![]() ![]() ![]() ![]() Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains ![]() |
I got them mounted, but there is a gap between the top of the headlightslid, and the front of the trunk edge. Is there some sort of adjustment that I don't see, that will allow me to to bring it closer together? I'm sure it's right in front of me.. (IMG:style_emoticons/default/blink.gif)
Attached thumbnail(s) ![]() |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
your hood is too far back to start...
TINCAN914 |
your hood is too far back to start... Seems obvious, but based on the distance between edge nearest the windshield, and the exposed front hood gasket, I thought the hood was to far forward. Estimate on the correct (if there is such a thing) gap distance between the hood and body nearest the windshield? Hope this makes sense.. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Gaps should be equal all the way around. front/back/left/right. Aligning the headlights is on the short list of PITA projects. Loosen the brackets. Fiddle with it. Tighten. Repeat 1000 times. Watch out because it's possible to move it too far back and it'll scrape the back edge when opening.
TINCAN914 |
Gaps should be equal all the way around. front/back/left/right. Aligning the headlights is on the short list of PITA projects. Loosen the brackets. Fiddle with it. Tighten. Repeat 1000 times. Watch out because it's possible to move it too far back and it'll scrape the back edge when opening. Thanks Mark. I will screw with it tonight. "It's possible to move it too far back and it'll scrape the back edge when opening" THis is what I want to avoid... |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Do a couple of things
Put blue masking tape on both the hood and the light cover. Remove the arm that attaches to the motor, and active it with your hand till you get it right, that way you can stop. There are two adjustments. The brackets that hold the whole assembly (under fender, and in the trunk) And the top actually can slide about 1/4 of an inch... Go slow, get it where you want it BEFORE you hook the motor up. Then add the wing in front of it. Rich |
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
Sell me the car and be done with it. (IMG:style_emoticons/default/biggrin.gif)
Or at least buy the 2.0 motor I have for sale. That car deserves way more than the wimpy 1.8 you have in it. (IMG:style_emoticons/default/tongue.gif) |
TINCAN914 |
Sell me the car and be done with it. (IMG:style_emoticons/default/biggrin.gif) The motor will have to wait. To much spent on the car already not to mention additional improvements on the house for the summer... Or at least buy the 2.0 motor I have for sale. That car deserves way more than the wimpy 1.8 you have in it. (IMG:style_emoticons/default/tongue.gif) |
Lo-Fi Version | Time is now: 11th July 2025 - 06:47 AM |
