Flashing brake light, Light fashes with e-brake handle released |
jwhcars |
Apr 26 2007, 04:33 PM
Member Group: Members Posts: 76 Joined: 25-February 07 From: Central Pa Member No.: 7,563 |
I read the pevious post ....now my dumb question.
Where is the master cyl.? I removed the pedal cluster cover did not see the reset switch,is it behind the sare tire? Duh even with the haynes book I am dumb,it is amazing what I have forgot in 35 years. (IMG:style_emoticons/default/huh.gif) I have managed to get new front pads on,oil changed and have the carbs adjusted to my area. |
914nerd |
Apr 26 2007, 04:47 PM
Who you callin' a "Member"? Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 |
The master cylinder is up under the car (pull the panel just behind the front trunk area and you will see it)
ClayPerrine |
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I read the pevious post ....now my dumb question. Where is the master cyl.? I removed the pedal cluster cover did not see the reset switch,is it behind the sare tire? Duh even with the haynes book I am dumb,it is amazing what I have forgot in 35 years. (IMG:style_emoticons/default/huh.gif) I have managed to get new front pads on,oil changed and have the carbs adjusted to my area. Remove the left front wheel. Look into the wheel well, and follow the tie rod back into the body. Below the tie rod is the master cylinder. You can reach in there and push the reset switch that is between the brake lines. |
jwhcars |
Apr 26 2007, 05:29 PM
Thanks for the replies, At least it was a good excuse to clean out the trunk.
By the way what is behind the black cover in the front trunk behind where there spare goes? I took the four screw out on the corners but what ever is behind it seems to be bolted to the cover,I did not want to remove the nuts holding what ever is behind there until I know what is there. |
Rand |
Apr 26 2007, 05:35 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
By the way what is behind the black cover in the front trunk behind where there spare goes? I took the four screw out on the corners but what ever is behind it seems to be bolted to the cover,I did not want to remove the nuts holding what ever is behind there until I know what is there. Fuel pump |
914nerd |
Apr 26 2007, 05:44 PM
Yeah
That's the fuel pump To get to the Master cylinder you need to start underneath the car Right behind the trunk is the cover for the steering rack and master cylinder pull off the 4 bolts holding it on and there you go |
jwhcars |
Apr 26 2007, 07:13 PM
Thanks for all the info,the light is now out-it must have been a loose connection because I never saw the reset swith but i did make sure the wire on the master cyl. was snug.
Hope to meet some of you at the swap meet this weekend. |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:18 AM |
