got to get to it, can't reach fitting |
machina |
Apr 26 2007, 05:42 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
my oil psi sender extension hose is leaking at the base where it goes into the block. it is hard to get to, about 2" below the level of the tin shroud. I really don't want to pull the tin off with the motor in the car, big PIA although i have done it.
any ideas on getting to it? i thought about getting a cheap wrench set and bending with some heat and BFH at right angle. Attached image(s) |
Aaron Cox |
Apr 26 2007, 05:43 PM
deep socket with a slot up the side to let the hose pass through it....
one of my specialty tools i made |
machina |
Apr 26 2007, 05:48 PM
john rogers |
Apr 26 2007, 05:49 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Or a crowsfoot would work. How did it get tightened in the first place, before the tin went on?
Aaron Cox |
Apr 26 2007, 05:54 PM
has to be a reaaaaally deep socket. i want to say 8mm was the size
NoEcm |
Apr 26 2007, 06:12 PM
Member Group: Members Posts: 95 Joined: 20-June 05 From: Seattle, WA Member No.: 4,309 |
i thought about getting a cheap wrench set and bending with some heat and BFH at right angle. BTDT on a wrench for another project. After bending the wrench it may or may not fit depending on the radius of the bend. It looks pretty tight down there. You might want to consider buying a cheap wrench, cutting it and then welding it back together to form an "L" shaped wrench. The radius will end up much tighter than if you bend it. |
spunone |
Apr 26 2007, 06:29 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
So Aaron you have one I may ask to borrow sometime in the near future
Aaron Cox |
Apr 26 2007, 10:21 PM
gotta find it first....
RoadGlue |
Apr 27 2007, 12:49 AM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
It's either 11 or 12 mm. I just did this yesterday. I purchased the line from aircooled.net, so if you bought yours elsewhere then it might be different. But it must be bigger than 8 or 9 mm...
So.Cal.914 |
Apr 27 2007, 01:00 AM
1/4" drive crows foot should work.
bperry |
Apr 27 2007, 01:45 AM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
You guys must have really small hoses.
Since my tins are off right now I measured mine. It was much bigger than I thought. Mine is actually 9/16" (~14.3 mm) yep its not metric, go figure. One thing that is true on mine is both ends have the same size nut on it. You can probably fit an open end wrench down in there far enough to figure out what size it is. Now you've got me wondering exactly what I've got. Guess I'll see if the threads are hopelessly stripped when I remove it. --- bill |
Dave_Darling |
Apr 27 2007, 10:08 AM
Since it doesn't need much torque on it, you might be able to get a pair of needle-nose vise-grips on it.
--DD |
rhodyguy |
Apr 27 2007, 10:19 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
go to the plumbing section of your local hardware store and buy a small Basin wrench. it'll work swell and they're fairly cheap. i'll go find one i have and post a picture is a few minutes.
k |
Lo-Fi Version | Time is now: 11th June 2024 - 04:45 AM |
