Need to go back to FI - What do I need?, Are you guys tired of FI/Carb question yet? |
1.8914 |
Apr 27 2007, 01:25 AM
Newbie Group: Members Posts: 25 Joined: 16-September 04 From: Stillwater, OK Member No.: 2,770 |
Hi everyone...I'm a newbie but been around a while soaking up knowledge. Thanks to all who spend so much time keeping the 914s of the world alive and kicking.
Anyway, my 2.0 has a set of Weber carbs that I believe are set up right but my neighbors have little kids and they are gettin sick of hearing the pop...sputter...pop in the mornings. (IMG:style_emoticons/default/yellowsleep[1].gif) When its warm the car runs and idles great but I'm entertaining going back to stock (or better) FI. The car has been carbed for 20+ years now so everything FI is long gone. Can you guys start a list for me of what I'll need and what I should pay to convert back over. (or maybe someone has a complete set-up they'd like to sell). BTW ...I have a Mallory Unilite - will that effect things? Thanks! Jeremy |
SirAndy |
Apr 27 2007, 01:54 AM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can you guys start a list for me pretty sure i'm missing a few things, but here it goes: D-Jet - FI brain - mounting bracket for the brain - FI engine harness - FI intake manifolds - FI throttle body - TPS - Fuel Rails - Injectors - CHT sensor - MPS - Fuel pressure regulator - FI fuel pump - high pressure fuel hose - correct air filter housing & filter - correct dizzy with FI trigger points - various vacuum hoses and needed connetors/Ts/splitters etc. - decel valve - AAR - working relay board with relays and all jumpers removed (that may have been added to run the carb motor) - stock fuel pump wiring (needs to come of the relay board as the pump is controlled by the FI brain) - multiple spade connector ground on top of engine case that'll get you started ... (IMG:style_emoticons/default/bye1.gif) Andy |
horizontally-opposed |
Apr 27 2007, 02:09 AM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
shaggy |
Apr 27 2007, 02:15 AM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
stock, rat9550 or web73 cam if then changed out your cam when they converted to carbs...
hope they didnt. cuz that means a bottom end rebuild if they did. -jim |
So.Cal.914 |
Apr 27 2007, 02:58 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
QUOTE "neighbors have little kids and they are gettin sick of hearing the pop...sputter...pop in the mornings. " My list will be shorter than Andys, what do you need? New neighbors... If it runs well with the carbs don't mess with it, unless you drive it around the yard they only hear it for awhile. |
ConeDodger |
Apr 27 2007, 09:33 AM
Apex killer! Group: Members Posts: 23,615 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Just get the carbs rebuilt and tuned. Art Thraen at ACE in Salt Lake can have them back to you in a week. While I agree that if someone has changed the cam, you will have a really hard time tuning it with the EFI I suspect that it will not be a RAT 9550 as the RAT was probably only 15 years old 20 years ago when your mods were done. (IMG:style_emoticons/default/biggrin.gif)
Bleyseng |
Apr 27 2007, 09:41 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I have a complete 2.0L Djet FI setup that I have reconditioned/checked. (all of Andy's list)
PM me if interested. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:03 AM |
