Going Backwards, Putting a T4 in a 911? |
GWN7 |
Dec 4 2003, 06:49 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
I have a chance to pick up a 71 911 (no motor or trans). has anyone every put a Type 4 engine/trans into a 911? What problems could be incountered?
Why you ask? Cause I have the engine and trans and don't have $7-8K to spend on one. (IMG:style_emoticons/default/smile.gif) |
Jeroen |
Dec 4 2003, 06:59 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
The factory did it with the 912E, so it is possible...
You might have a problem with the exhaust system though (if you want heat) cheers, Jeroen |
Jake Raby |
Dec 4 2003, 07:19 PM
Itcan be done..... but the gearing is wrong...
Joe Bob |
Dec 4 2003, 07:45 PM
tony.bray@peregrine.com
Did it to an early 912.....changed the trans. |
Brad Roberts |
Dec 5 2003, 01:34 AM
If things work out right.. you may see more 911's with T4's. Come on Jake.. we need a 3.0 T4.
I think a 7:31 early 915 would be the way to go with a 2056 with a nice cam. B |
Jake Raby |
Dec 5 2003, 01:37 AM
As long as we make that 915 conversion flywheel.
Joe Bob |
Dec 5 2003, 07:48 AM
A nice 67 912 just went on sale here local...5K. BTW Kennedy Eng already makes the flywheel....and the early 912s are a 901 trans....
need4speed |
Dec 5 2003, 10:40 AM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
I think I have a "912" badge sitting around somewhere from when I put my 1600cc T1 912 engine in the Ghia. I was contemplating putting that on the decklid, but good taste won out.
Britain Smith |
Dec 5 2003, 11:43 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I am currently working on putting a 2.3L Turbo Type-4 in the back of my 912. The project has to go through now as I sold my nice 912 engine in the quest for more power.
About that flywheel...are you sure they make a flywheel for the 915 with the type-4 mounting? I am currently in the market for an early 915 tranny. -Britain |
airsix |
Dec 5 2003, 11:56 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
I would be willing to help anyone with a running 911 do a type-iv conversion. I'll supply the type-iv and will even haul off the old six for you.
-Ben M. |
seanery |
Dec 5 2003, 12:02 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Ben,
You're a helluva guy! |
Joe Bob |
Dec 5 2003, 12:06 PM
ArtechnikA |
Dec 5 2003, 01:02 PM
QUOTE(Britain Smith @ Dec 5 2003, 09:43 AM) About that flywheel...are you sure they make a flywheel for the 915 with the type-4 mounting? used to be a factory part, no idea if they're still available, or if tyhere were bellhousing changes on the 'E (i remember -something- about that, can't recall details...) takes clutch pressure plate 901.116.001.01 and clutch disc 914.116.011.01 - flywheel 022.105.273.A |
airsix |
Dec 5 2003, 01:25 PM
QUOTE(seanery @ Dec 5 2003, 10:02 AM) Ben, You're a helluva guy! Thanks. I do what I can. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 4th June 2024 - 03:41 PM |
