Replacing an 009 with a Mallory, What do I need? |
terrymason |
May 3 2007, 09:45 AM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil.
Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? 2. Is this really as easy as dropping it in and timing the car? 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? 4. Will I be able to move this over when I swap to a 2.0? 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. |
ConeDodger |
May 3 2007, 10:07 AM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil. Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? No 2. Is this really as easy as dropping it in and timing the car? Yes 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes 4. Will I be able to move this over when I swap to a 2.0? Yes 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. If you have a weld in bung and an O2 sensor or you are just using the LM to tune with a tailpipe sniffer it will work. It doesn't "interface" directly if that is what you mean. |
ConeDodger |
May 3 2007, 10:08 AM
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil. Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? No 2. Is this really as easy as dropping it in and timing the car? Yes 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes 4. Will I be able to move this over when I swap to a 2.0? Yes 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. If you have a weld in bung and an O2 sensor or you are just using the LM to tune with a tailpipe sniffer it will work. It doesn't "interface" directly if that is what you mean. Wait... Not sure about the sitting in the driveway and listening to the radio... Anyone??? Does the Mallory burn up if it is sitting just right with an open ignition? |
terrymason |
May 3 2007, 10:13 AM
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil. Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? No 2. Is this really as easy as dropping it in and timing the car? Yes 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes 4. Will I be able to move this over when I swap to a 2.0? Yes 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. If you have a weld in bung and an O2 sensor or you are just using the LM to tune with a tailpipe sniffer it will work. It doesn't "interface" directly if that is what you mean. On the LM - I've got a weld in bung to sniff the exahust. I was wondering perhaps if the mallory could be influenced / timed by the LM. |
So.Cal.914 |
May 3 2007, 10:44 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil. Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? No **Yes- Maybe not today, maybe not tomorrow, but soon you will have the uncontrollable urge to replace everything with the best...there's no escape. 2. Is this really as easy as dropping it in and timing the car? Yes ** No- Don't forget you will be in the engine compartment for a long period of time and you will have a chance to count just how many things need attention. Powder coating the engine tin will be a must... 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes **Well...I put my radio on a non switched hotwire (fused) so I don't have anything else drawing power that does not need to. 4. Will I be able to move this over when I swap to a 2.0? Yes ** No- by then there will be something better and you will just have to get it... 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. Nope and no I-PODS [color=#FF0000]eather. If you have a weld in bung and an O2 sensor or you are just using the LM to tune with a tailpipe sniffer it will work. It doesn't "interface" directly if that is what you mean. (IMG:style_emoticons/default/biggrin.gif) |
terrymason |
May 3 2007, 11:01 AM
Thanks guys. About this
3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes **Well...I put my radio on a non switched hotwire (fused) so I don't have anything else drawing power that does not need to. What exactly happens here? I'm assuming that the mallory will receive voltage whenever the ignition is on, and if that voltage isn't used within some amount of time, then it will burn up? is that fairly accurate? |
ConeDodger |
May 3 2007, 11:17 AM
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil. Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? No **Yes- Maybe not today, maybe not tomorrow, but soon you will have the uncontrollable urge to replace everything with the best...there's no escape. 2. Is this really as easy as dropping it in and timing the car? Yes ** No- Don't forget you will be in the engine compartment for a long period of time and you will have a chance to count just how many things need attention. Powder coating the engine tin will be a must... 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes **Well...I put my radio on a non switched hotwire (fused) so I don't have anything else drawing power that does not need to. 4. Will I be able to move this over when I swap to a 2.0? Yes ** No- by then there will be something better and you will just have to get it... 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. Nope and no I-PODS [color=#FF0000]eather. If you have a weld in bung and an O2 sensor or you are just using the LM to tune with a tailpipe sniffer it will work. It doesn't "interface" directly if that is what you mean. (IMG:style_emoticons/default/biggrin.gif) Gotta love a smart-ass! (IMG:style_emoticons/default/biggrin.gif) I have patients ask me if they are going to die all the time.... It is really hard to resist the urge to say "well, yes... but we all do eventually." |
Rand |
May 3 2007, 11:42 AM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Thanks guys. About this 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes **Well...I put my radio on a non switched hotwire (fused) so I don't have anything else drawing power that does not need to. What exactly happens here? I'm assuming that the mallory will receive voltage whenever the ignition is on, and if that voltage isn't used within some amount of time, then it will burn up? is that fairly accurate? The point is to run a separate circuit that lets you run the radio withOUT the ignition switch on. If I had a stereo, that's what I would do. |
JmuRiz |
May 3 2007, 01:13 PM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Personally I'd e-mail or call Jake Raby, he sells them all setup and ready to go. Probably the easiest way to do the swap. Then again I don't have one, I just use a Crane system...but if I did it now I'd go Mallory.
Joe Ricard |
May 3 2007, 02:57 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
You have a radio? and you can hear it while the engine is running?
You need a header that'll fix it. |
rhodyguy |
May 3 2007, 03:34 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if your radio is powered by a non-keyed source i don't *think* it will have any adverse effect on the igintion module listening to tunes with the engine off. but if it does, it will cost you a quick c-note if the i.m. goes south. i left the key on when i rolled the 73' into the garage (bat out) so the wheel would be unlocked. when i connected the bat, i think that's when the i.m. burned up. key was still in on position.
k |
lotus_65 |
May 3 2007, 06:43 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
this article was interesting:
mallory do they just go out, and stop working, or is the hesitating i feel on acceleration a condition of one that is bad, anyone know? |
Jake Raby |
May 5 2007, 09:48 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I have had ONE unit fail out of over 1,000 of them that we have sold and used while someone was driving the car. We have had a few dozen of them destroyed while they were being installed and most of the time thatb was due to them being hooked up to other types of coils and spark boxes that were not compatible.
I trust one everyday, the unit thats in my 912E has 105K miles on the original dizzy cap and rotor! I have a Mallory in every car that I own and have for the past 6 years |
rhodyguy |
May 5 2007, 10:02 AM
what flavor of coils do you use jake? i screwed the pooch on the hook up. no doubt about it.
k |
Lo-Fi Version | Time is now: 10th June 2024 - 06:22 AM |
