Can I get rid of these ?, Cooling doors |
JBart |
May 5 2007, 01:17 AM
UNDER CONSTRUTION Group: Members Posts: 110 Joined: 9-October 06 From: Wildomar Ca. Member No.: 7,019 |
I need some help here . I dropped my engine to fix some major oil leaks . I'm wondering if I can take this nonworking assy. out while I have the tin off I don't have a T-stat. so i'm thinking it won't hurt to remove them. Am I correct in my thoughts? Here are some pics. of what i'm talking about.
Thanks, jbart Attached image(s) |
So.Cal.914 |
May 5 2007, 01:20 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
You live in CA so I don't see a problem, just need to let it warm up a bit.
DanT |
May 5 2007, 01:21 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
the one over the oil cooler can be rivited down to permanently blow air into the oil cooler. the one on the other side can be eliminated.
at least for my track car... (IMG:style_emoticons/default/biggrin.gif) that is exactly what I have done. And mine was still working properly. (IMG:style_emoticons/default/happy11.gif) |
toon1 |
May 5 2007, 01:23 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
maybe the top one,maybe, if you have no plan to use the belows. Definitly not the bottom one, it directs the air over teh oil cooler
JBart |
May 5 2007, 01:26 AM
DanT |
May 5 2007, 01:32 AM
there is a pulley system on the bottom left side of the motor that connects to a bellows that heats up, expands and then closes/opens the doors in the manner you found them.
It is an aircooled version of a thermostat on a water cooled motor.. |
BarberDave |
May 5 2007, 04:36 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I would find a T-stat ,pulley.and wire to make the thing fuction properly. Porsche engineers disigned it that way for a reason. my 2 cents Dave (IMG:style_emoticons/default/slap.gif) |
MecGen |
May 5 2007, 07:10 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi
Sorry man, you got to keep em. Get the T-stat working, even in Cali. When you remove flaps in the cooling system, (they actually route air to the rite places,) the motor will run hotter in all the wrong places. The cooling system is very well thought of, but it needs to be working on a T4. Later (IMG:style_emoticons/default/beerchug.gif) |
URY914 |
May 5 2007, 08:23 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,967 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Hi Sorry man, you got to keep em. Get the T-stat working, even in Cali. When you remove flaps in the cooling system, (they actually route air to the rite places,) the motor will run hotter in all the wrong places. The cooling system is very well thought of, but it needs to be working on a T4. Later (IMG:style_emoticons/default/beerchug.gif) I agree 100%. Street cars need these pieces to work. Everything is there for a very good reason. |
computers4kids |
May 5 2007, 09:01 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
(IMG:style_emoticons/default/smilie_pokal.gif) I would find a T-stat ,pulley.and wire to make the thing fuction properly. Porsche engineers disigned it that way for a reason. my 2 cents Dave (IMG:style_emoticons/default/slap.gif) Hi Sorry man, you got to keep em. Get the T-stat working, even in Cali. When you remove flaps in the cooling system, (they actually route air to the rite places,) the motor will run hotter in all the wrong places. The cooling system is very well thought of, but it needs to be working on a T4. Later (IMG:style_emoticons/default/beerchug.gif) Hi Sorry man, you got to keep em. Get the T-stat working, even in Cali. When you remove flaps in the cooling system, (they actually route air to the rite places,) the motor will run hotter in all the wrong places. The cooling system is very well thought of, but it needs to be working on a T4. Later (IMG:style_emoticons/default/beerchug.gif) I agree 100%. Street cars need these pieces to work. Everything is there for a very good reason. If this a street 914 you will be real sorry if you don't keep the flaps...by default if the thermostat cable breaks, the flaps are positioned for full cooling. You can buy a new thermostat and cable from evparts for less than $100. You want your engine to warm up...if not, the wear on the engine running cold longer comes at a high price. The type three coil opens 10 degrees sooner than the OEM type 4...but not that big of a deal. Attached image(s) |
Cap'n Krusty |
May 5 2007, 09:20 AM
QUOTE "If this a street 914 you will be real sorry if you don't keep the flaps...by default if the thermostat cable breaks, the flaps are positioned for full cooling. You can buy a new thermostat and cable from evparts for less than $100. You want your engine to warm up...if not, the wear on the engine running cold longer comes at a high price. The type three coil opens 10 degrees sooner than the OEM type 4...but not that big of a deal." Of course you shouldn't let the fact that the T3 part won't fit get in your way ..................... How ya gonna attach the wire? T4 ones are available. For the street, running the flaps in the default position is a good option. The Cap'n |
computers4kids |
May 5 2007, 09:28 AM
QUOTE "If this a street 914 you will be real sorry if you don't keep the flaps...by default if the thermostat cable breaks, the flaps are positioned for full cooling. You can buy a new thermostat and cable from evparts for less than $100. You want your engine to warm up...if not, the wear on the engine running cold longer comes at a high price. The type three coil opens 10 degrees sooner than the OEM type 4...but not that big of a deal." Of course you shouldn't let the fact that the T3 part won't fit get in your way ..................... How ya gonna attach the wire? T4 ones are available. For the street, running the flaps in the default position is a good option. The Cap'n The T3 does fit...EVparts sells a cable kit with the correct T4 coupler for $20...it's all plug-n-play. I didn't realize T4 thermostat's were available...I couldn't find one when I was looking for one a few months ago. I wanted a new one... |
type47 |
May 5 2007, 09:43 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
QUOTE "If this a street 914 you will be real sorry if you don't keep the flaps...by default if the thermostat cable breaks, the flaps are positioned for full cooling. You can buy a new thermostat and cable from evparts for less than $100. You want your engine to warm up...if not, the wear on the engine running cold longer comes at a high price. The type three coil opens 10 degrees sooner than the OEM type 4...but not that big of a deal." Of course you shouldn't let the fact that the T3 part won't fit get in your way ..................... How ya gonna attach the wire? T4 ones are available. For the street, running the flaps in the default position is a good option. The Cap'n maybe he just mis-identified the type as i think it's actually a type I thermostat adapted to work on a type IV |
computers4kids |
May 5 2007, 10:00 AM
Yes, your right...it is a Type 1, not a Type 3 thermostat that converts nicely for a Type 4 motor...sorry for the confusion. Here is a great article on the Type 4 thermostat with pics...worth the read. Attached image(s) |
SirAndy |
May 5 2007, 12:35 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Am I correct in my thoughts? NO you need the flaps. especially the one over the oil cooler. look at how the air system works. if you remove that flap you will have *NO* air going through the oil cooler at all! you're going to cook your engine in no time ... the flap over the oil cooler actually forces air into the cooler when it's DOWN and covering the top of the cooler! (IMG:style_emoticons/default/cool_shades.gif) Andy |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:26 AM |
