whitey |
Member ![]() ![]() Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 ![]() |
I'm going to replace my tunnel lines...can I get away with fabricating my own lines out of brake line (what size-2.0 FI) or should I buck up for the stainless lines?
Thanks |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
I have done a couple of my cars, not FI however but I used brake lines, they are stainless and they work great. I would think for FI you would use a 5/16 and 1/4? They only come in 5' lengths from Kragen which gets you from the front to the rear only. You would use rubber line from there. I bought a flaring tool and bender when I did my first carb conversion. Now all I do is V8 cars so I only need one line and block off the return line at the front.
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
I used a pair of 5/16" mild steel brake lines from NAPA. (Those must be for trucks since I've never seen a car that used brake lines that big.) Got a 5' length for the tunnel and a shorter one for the engine compartment. Used a brass 90 degree fitting to make the turn. Used a Harbor Freight tubing bender to bend the heck out of the short lines so they come up in the stock location. It's a really nice custom job, if I do say so myself. (IMG:style_emoticons/default/wink.gif)
If I had it to do over again, I would buy the stainless kit. No muss, no fuss, just install it and be done with it. But it wasn't available yet when I did the job. This was for a 2.0 D-jet car and it seems to be getting enough fuel. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Buy the lines from Chris and be done with the replacement.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
3/8" and 5/16" Stainless Tube (I bought 10' lengths)
or better yet buy them from Racer Chris. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
(IMG:style_emoticons/default/agree.gif) no hassle deal with the ones chris offers. i know i would go thru atleast 2 10' pieces if i tried to make them. i'd have to buy the tubing bender set. tinkering is not my thing. even taking the end off of a coil wire and replacing it is pushing the limits. (IMG:style_emoticons/default/biggrin.gif)
k |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
If you are not going to race it, why not just use a good quality fuel injection hose the entire length? I don't know why everyone goes to the hassle of metal lines and all the fittings since the newer style hose is very good and designed for high pressure. Racing does prohibit this though. The rubber lines only take a couple of minutes to run.
I ran mine from the front fuel pump directly to the rear filter without any additional fittings. I slid some heat shrink over the portion inside the car for abrasion resistance and some temp insulating sleeve over the outside portion. ![]() ![]() |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
If you are not going to race it, why not just use a good quality fuel injection hose the entire length? I don't know why everyone goes to the hassle of metal lines and all the fittings since the newer style hose is very good and designed for high pressure. Racing does prohibit this though. The rubber lines only take a couple of minutes to run. I ran mine from the front fuel pump directly to the rear filter without any additional fittings. I slid some heat shrink over the portion inside the car for abrasion resistance and some temp insulating sleeve over the outside portion. ![]() ![]() Wow, you have the car up on a single scary style jackstand. I'm not getting under there. (IMG:style_emoticons/default/poke.gif) |
skline |
He was just demonstrating the amazing balance his car has!! I wouldnt get under there either. (IMG:style_emoticons/default/huh.gif)
Lo-Fi Version | Time is now: 17th June 2024 - 11:27 AM |
