914 parts nerds needed..., Need to know... |
ConeDodger |
May 7 2007, 04:45 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Is the 914 temperature sender that goes in to the taco plate the same as the 914-6 part number? My parts guy cannot seem to find one for the 914-4 and thinks they are the same part.
SirAndy |
May 7 2007, 04:48 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is the 914 temperature sender that goes in to the taco plate the same as the 914-6 part number? My parts guy cannot seem to find one for the 914-4 and thinks they are the same part. i'm pretty certain they're not the same. but i have been wrong before ... are you sure your parts guy is looking at the right year? early cars didn't have a sending unit. (IMG:style_emoticons/default/smile.gif) Andy This post has been edited by SirAndy: May 7 2007, 05:03 PM |
skline |
May 7 2007, 04:50 PM
The first year was 73 as it came in the "S" model (IMG:style_emoticons/default/smile.gif)
McMark |
May 7 2007, 05:13 PM
I don't think the electrical functionality changes all that much from sender to sender, but the range might (i.e. 250* max would be different from 350* max). It's more likely that you'll run into thread pitch/size issues.
914/4 Temp Sender: E039.919.268 Pelican Parts lists it as NLA. 914/6 Temp Sender: 901.641.632.00 |
skline |
May 7 2007, 05:15 PM
Mark is right, PET shows that part number as a sender and it has to do with the oil.
skline |
May 7 2007, 05:17 PM
Here it is
Attached image(s) |
2-OH! |
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
Isn't it a case of the gauge and the sender have to match...Other than that, it does not matter... The temp range has to be correct for the motor...
Call North Hollywood Speedo and ask them...They sell and repair, both 2-OH! |
McMark |
May 7 2007, 05:45 PM
The gauge and the sender 'match' by having the output of the sender match the range shown on the gauge. There is no such thing as having to use a 911 sender with a 911 gauge. Many people have swapped fuel gauges from the stock version to a VDO round version. If you have an oil pressure gauge that reads up to 80 psi, than any 0-5 bar sender will work. 911, 914, whatever. You might have a slight discrepancy if you switch brands (autometer with VDO, etc) but I would be skeptical of even that.
Lo-Fi Version | Time is now: 10th June 2024 - 04:47 AM |
