early horn button backdating, how'd you do it? |
brer |
May 8 2007, 12:03 AM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
I've got my wheel done and on, the contact ring is in place with the wire running through the wheel to plug into the horn button.
My setup is off my 73, and is not the early style hub. I've got an early 911 horn button, GT style with leather insert, but how to connect to make it work? Who's done this? Do you need an early hub? or can you just rig up the button? I'm interested in options that dont involve finding an early hub for my wheel. |
brer |
May 8 2007, 10:17 AM
would pictures help? (IMG:style_emoticons/default/confused24.gif)
dflesburg |
May 8 2007, 10:18 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
yes
KaptKaos |
May 8 2007, 11:22 AM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Can't be done. Sorry to tell you. Maybe you should just send me that horn and put it out of your mind. (IMG:style_emoticons/default/laugh.gif)
Aaron Cox |
May 8 2007, 11:31 AM
i thought the horn pad installed just lije the 914 one... twist on, twist off.
echocanyons |
May 8 2007, 11:40 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
brer |
May 8 2007, 12:19 PM
I gots me the copper ring on the back of the wheel with the wire coming off of it. This feed through a hole in the steering wheel and has a spade connector on it.
But I dont have anywhere to connect it to the early button. The early button uses the spring loaded pin that goes through the wheel right? I gots no pin, and no idea where to plug my wire. (IMG:style_emoticons/default/confused24.gif) twisting on and off I figured out myself. (IMG:style_emoticons/default/smile.gif) |
Martin Baker |
May 8 2007, 02:16 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
This type of horn button requires the button type contact, like the 911,914-6, 356 etc...not sure if the later wheels have the hole in them for this contact...it does not use a wire for power. The contact rubs the ring, and contact a spot on the horn button.
dflesburg |
May 8 2007, 02:19 PM
brer,
please show us with a picture how you solved it.... |
balljoint |
May 8 2007, 02:34 PM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
When I was first playing with mixed early and late horn setups I made a teeny error which resulted in a horn honk every time the steering wheel was turned more than 30 degrees from 0 either way. Just about wet myself turning out of the parking lot for the first time. (IMG:style_emoticons/default/smile.gif)
brer |
May 8 2007, 02:59 PM
this is where I was hoping someone had tackled this before.
I've got a hole in the wheel, but the hub is a later hub so the hole is blocked. I think we need photos. more later .....if anyone has an extra pin I might need one. |
Lo-Fi Version | Time is now: 4th June 2024 - 02:32 AM |
