Parking Brake, really would like it to work |
blitZ |
May 9 2007, 07:20 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I've gone through my brake system, new MC, complete flush and bled well, vent clearance adjusted. However, I can't seem to be my parking brake working. I've adjusted the cable behind the firewall and can get the drivers side to grip, but the passenger does not. Is it possibe the cables have stretched over time?
tdgray |
May 9 2007, 07:52 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Absolutley but I would run through the system again and make sure you have everything adjusted.
IIRC you can adjust each cable independently ( R and L)... or I may be thinking of my MGA....hmmm |
ws91420 |
May 9 2007, 07:57 AM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Absolutley but I would run through the system again and make sure you have everything adjusted. IIRC you can adjust each cable independently ( R and L)... or I may be thinking of my MGA....hmmm Left and right adjust independently where they exit the tubes from the firewall into the engine bay. Also setting the venting clearance of the rear calipers need to be done as the pads wear. |
Dr Evil |
May 9 2007, 09:59 AM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Welby hit it onthe head, you need to adjust the vent clearance of the rear pads before you adjust the cables. This may lead to the finding thatyour back brakes were not working as well and should increase your overall braking.
blitZ |
May 9 2007, 11:29 AM
Thanks.
I'll recheck my clearances. Also, found a few other posts, probably need to check the lever on the caliper. |
Eric_Shea |
May 9 2007, 02:36 PM
QUOTE Also, found a few other posts, probably need to check the lever on the caliper. Probably not... (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:54 AM |
