I think I screwed up..., Engine in, front sideshift bar not |
bondo |
May 10 2007, 01:05 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I put the engine in (with jkeyzer's help), but not the shift bar. Now I can't seem to get the shift bar in. I did manage to get the bushing in though. (IMG:style_emoticons/default/smile.gif)
It's an early car (70) and a sideshift bar. I'm using a regular tailshift bushing because the previous owner of the sideshift bar put a sleeve on it instead of using a conversion bushing. I can get it most of the way in through the bottom or the top, but not all the way. Am I screwed? Does everyone that does a sideshift conversion have to pull the engine? Can I get by with putting a jack under the engine and just removing the engine mounting bar? |
Mike D. |
May 10 2007, 01:15 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Justinp71 |
May 10 2007, 01:26 PM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I ran into this a couple of months ago.
We lifted up the engine a couple of inches (in the front), I believe the engine mount bar must have been removed. (IMG:style_emoticons/default/biggrin.gif) |
TonyAKAVW |
May 10 2007, 01:27 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Ditto Mike D.'s comments. Though I would use a jack stand under each head, or at least be careful if you are using just a jack.
Or even better. If when installing the shift bar, you are not able.... Go cable! You have the cable shifter ready for the other car, just make a second one (IMG:style_emoticons/default/smile.gif) |
Joe Ricard |
May 10 2007, 01:50 PM
bondo |
May 10 2007, 02:16 PM
Yup, that sucked. It's in now though. Thanks for the help!
Lo-Fi Version | Time is now: 12th June 2024 - 04:33 AM |
