Valve Train Geometry setup |
G e o r g e |
May 10 2007, 10:42 PM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
I'm down to this and have read and searched,
but I am still unsure the best/easiest way to set up my dial indicator efficiently. anyone have any pics or suggested attachment techniques? Have i missed the perfect thread on this? only having late after hours to work on this is wearing me out anyone in socal have a jig setup that i can borrow? |
Aaron Cox |
May 10 2007, 11:04 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i have an adjustable pushrod..... brando's got it.... but its yours if you need it.
joe sharp helped me dial in mine, give ole Joe a call. Its really simple once you wrap your head around it. |
craig downs |
May 11 2007, 02:53 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Ahh so your doing valve geo to. I just strated doing mine. I took a piece of 2" wide
steel flat bar drilled a 5/16 or 8mm hole a corner and bolted it down across the intakes for the magnegtic base for the dial indicator. Attached image(s) |
craig downs |
May 11 2007, 03:00 AM
one more
Attached image(s) |
Aaron Cox |
May 11 2007, 08:35 AM
as borat say "Very Nice!"
G e o r g e |
May 11 2007, 08:39 AM
(IMG:style_emoticons/default/agree.gif) With Aa it is very nice .
where did you get the magnet-arm setup from? |
Aaron Cox |
May 11 2007, 08:41 AM
george, i also have the magbase + dial indicator if you wish to borrow that also LOL
i got mine at HF |
ConeDodger |
May 11 2007, 09:53 AM
Apex killer! Group: Members Posts: 23,596 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Jake has an article on his forum. McMark is very good with this. No. VERY GOOD. His set up is similar...
G e o r g e |
May 11 2007, 12:50 PM
G e o r g e |
May 11 2007, 12:53 PM
Jake has an article on his forum. McMark is very good with this. No. VERY GOOD. His set up is similar... Have read and reread jakes article And I'm sure Mark is Very good at this, but he's 8 hrs north of me (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/biggrin.gif) |
Borderline |
May 11 2007, 01:15 PM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
The shaft on the magnetic base can be un-threaded from the base. I drilled and tapped a couple holes on a small plate. The shaft threaded into the plate and then the plate was held down by one of the intake studs. I found that the magnetic bas a little awkward to work with. Sorry, no photos that show all the details. Just don't let the mag base get in your way.
Jake Raby |
May 11 2007, 03:37 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
If my 9000 word essay on the subject can't get you through it pain free there is a problem!... If that essay is folowed step by step with the correct tools and parts in hand its a simple process.
G e o r g e |
May 11 2007, 04:21 PM
If my 9000 word essay on the subject can't get you through it pain free there is a problem!... If that essay is folowed step by step with the correct tools and parts in hand its a simple process. Essay directions are plain and simple. not asking, before going to the store, where to buy every tool needed was my problem |
Jake Raby |
May 11 2007, 04:48 PM
We won't be selling the tools- only renting them....
G e o r g e |
May 11 2007, 04:58 PM
914werke |
May 11 2007, 08:48 PM
"I got blisters on me fingers" Group: Members Posts: 10,085 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
is this possible to accomplish ..in car? (IMG:style_emoticons/default/wub.gif)
Jake Raby |
May 11 2007, 09:42 PM
That would be a real bitch.. It wpuld be faster and more accurate if you pulled the engine... I woulld not even think of doing it in the car! |
craig downs |
May 11 2007, 10:15 PM
Maybe we should get together and do both of ours. I understand how to do it and it
isn't very hard just takes time. |
G e o r g e |
May 11 2007, 10:19 PM
JoeSharp |
May 11 2007, 11:42 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) Whats up??? And where is it going to happen???
Lo-Fi Version | Time is now: 23rd May 2024 - 06:27 AM |
